Mike-73
Jun 02, 2021Aspirant
ReadyNAS 422 - MS OneDrive SYNC Problems
Having terrible problems with sync between onedrive and also my ReadyNAS 422.
Tried disconnecting and reconnecting, response is slow, can create files on the onedrive which get picked up on the NAS. However trying to create a file on the NAS doesn't go up to the one drive.
Set to bidirectioal and this has previously been working however of late is failing.
I've tried clearing space off reduce the amount that is sharing, no use....
I've tried support, no longer anything available
If anyone could advise i'd be very grateful. I did have a similar problem some time ago, at that point i turned off the onedrive option on the NAS control panel and then restarted, seemed to work. It doesn't this time, so i have files on one drive now only partially dragged over to the NAS
Struggling.....
- JohnCM_SNETGEAR Employee Retired
Hi Mike-73,
May I know the current firmware version of your NAS?
You may also download the NAS system logs and check the one-drive.log. We may be able to find the cause of the issue there.
