aglight63
Aug 10, 2018Aspirant
ReadyNAS 516 Degraded Volume
RN516 showed Disk went from ONLINE to FAILED, I pulled a drive from spare RN516 (that had been factory reset).
Before swapping drive, I rebooted the NAS, upon reboot, I received "No Volumes exists...
JohnCM_S
Aug 10, 2018NETGEAR Employee Retired
Hi aglight63,
Welcome to the Community!
Do you have a backup of your data?
Please download the complete system logs of the NAS and then provide it to us. You may check this link on how you can send it.
- aglight63Aug 14, 2018Aspirant
:smileysad:
That was our data backup
- Jedi_KnightAug 14, 2018Tutor
Try this. Read it all the steps before doing it.
Step(s):
1. Completely shutdown the system.
2. Remove the disk #4.
3. Power "On" the system and let the system completely boot up.
4. You exisiting data volume should be online and marked as degraded.
5. Insert the disk #4 while the system is power on. wait for about 3-5 minutes and see if the volume start recovering.
If not, asked for Netgear L3 Support Help.
Good Luck.
Thanks Jedi_Knight
I powered off NAS,
removed disk 4,
powered on,
@ step 4, NAS shows just as it does in picture above;
all 5 disks 1,2,3,5,6 are red
disk 4 is black(that I pulled out of a spare NAS) but has a green light instead of no light
still showing No volumes exist
and "Remove inactive volumes to use the disk. Disk #1,2,3,5,6
Still hoping,
AL
