Atof
Sep 20, 2018Aspirant
ReadyNAS 6.9.4 hidden file issue (leading dot and underscore)
I have an application (Lattice Diamond) which tries to create obscure hidden files like ._tmp_vxd_ or ._Real_._Math_.vhd (leading dot plus underscore) which do not work on V6.9.3 and V6.9.4 via S...
- Sep 24, 2018
Almost an industry standard. For macOS SMB compatibility, they are loading the vfs fruit - by default, this vfs does veto ._ files adding something like...
fruit:veto_appledouble = no
...might cure. Not deep enough in customizing ReadyNAS SAMBA config, I'm more on the Q side when it comes to NAS. StephenB you might continue here based on this information please.
Atof
Sep 24, 2018Aspirant
Great to know I'm not alone. ;-)
Just tried to create such a file "._bla" right from the SSH on the NAS (and adjusted owner/group/access to match other files) which worked as expected. Interesting point is, that this file is not even enumerated through SMB, neither on Windows (DIR /AH) nor on MacOSX terminal (ls -la). If I rename it on the console
mv ._bla .1bla
it shows up immediately.
Looks like this prefix has some very special meaning now.
I just run a
find /data -type f -name "._*"
on the NAS console which revealed plenty of those files (mostly created by Mac but not all), so this had worked some time before.
schumaku
Sep 24, 2018Guru - Experienced User
