AusS2000
Aug 25, 2014Tutor
ReadyNAS Data Recovery - Duo v2
I came here from Erik's post on First Person Troubleshooter. Couldn't post a comment there for some reason. I'm running VMware on Mac and have successfully launched the Debian instance but cannot g...
AusS2000
Sep 16, 2014Tutor
There is no issue with the V2 other than my firewall was circumvented and a bunch of files deleted off it.
Thanks for the code. Are you suggesting I enter that in the terminal of the Debian instance that is trying to mount the volume?
Or that I should put the drive back in the V2 and SSH to it and enter it there?
