AndyEd
May 28, 2013Aspirant
ReadyNAS Duo - Cannot Login - Help!
Hi Guys, Not sure if this is the right place, but here goes... For some reason the my ReadyNas Duo running 4.1.10 stopped letting me log in a few days ago. I can still see all the shares and ...
May 28, 2013Guru - Experienced User
It should be admin/netgear1.
Did you try your old admin password? Are you still seeing your shares? What status info does RAIDar give you?
BTW, I think the guide in the duo hardware manual is clearer than the faq (http://www.downloads.netgear.com/files/ ... 6Dec11.pdf)
