joah
Feb 09, 2016Aspirant
ReadyNas DUO backup error - 'read only file system'
Hello community,
I hope you can help me with an issue i'm having with my ReadyNAS Duo (v1) running Raidiator 4.1.14. At night it runs a backup job which copies a folder from a computer on the LAN to the NAS itself. What often happens is after a reset things work for a while, sometimes days, sometimes weeks. But then I get warning emails containing log entries like:
cp: cannot create regular file '/backup/projecten/./CAM_strip/01_v0.1.JPG': Read-only file system
Usually this warning is given for every file (meaning thousands) so the emails are quite big. And obviously the backup has not been made. I tried troubleshooting this issue and searched for similar issues on this forum and on the web, but to no avail. I can't seem to pinpoint what is causing this.
Perhaps you could help me out running through some of the settings, i may have been tinkering too much. I suppose it has something to do with ownership and rights to access these files and folders.
Thanks!
Hi joah,
Aside from trying StephenB and JennCs suggestions, if you will create a test share, can you tell us if you will experience the same read-only behavior?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
I don't know what is causing it - but I am wondering if resetting the file ownership/permissions on the backup share solves it.
- joahAspirant
I'm afraid resetting the ownership hasn't helped.
One odd thing I noticed is that the first warning email arrives at 02:39 at night. But the backup is scheduled to start at 04:00. So it seems to be failing before it has even begun? The next couple of emails arrive at 05:35, 08:50 and 12:03.
- joahAspirantI noticed another email sent at 04:09, containing just two lines like this: .
cp: cannot open '/job_001//_Projecten/./OBB_Zoetermeer folders/~folder_v0.1~07$hih.idlk' for reading: Text file busy
Which might actually be correct since these were documents currently opened and unsaved in InDesign. I usually leave my computer running overnight with programs and documents opened.
- joahAspirant
Ok, done. Let's see what happens tonight.
- JennCNETGEAR Employee Retired
Hello joah,
Here's the article in case you need it:
http://kb.netgear.com/app/answers/detail/a_id/14682/~/resetting-permissions-on-raidiator-4
- mdgm-ntgrNETGEAR Employee Retired
How full is the data volume on the NAS?
