masa2
Jun 27, 2012Tutor
Readynas Duo Factory reset and boot
I want to reset my Readynas to factory defaults. I held down reset button 30 seconds and Disk 1 & 2 leds flashed a few times. I did this with these instructions: Duo / NV / NV+ / X6/600 ...
- Jun 27, 2012Bad disks detected indicates that one or more disks is bad. A factory reset would fail due to the one or more bad disks.
I would suggest removing the disks (label order) and connecting them to an internal SATA port in your PC and checking them using vendor tools
masa2
Jun 27, 2012Tutor
Yes I checked and I'm sure
