Abernus1
Jun 23, 2013Aspirant
ReadyNAS Duo File System Check
Hi all, I recently went away and decided to power down my Duo. I loaded RAIDar v4.3.4 and logged on to my Duo and powered it down, all went O.K with no errors. When I can home I loaded RAIDar and...
Abernus1
I am unable to connect to the Duo fron RAIDar as the only option I have is rescan and Locate, the setup and browse options are grayed out. I am also unable to connect to the Duo via the IP address, however I can ping the IP address of the Duo
