Abernus1
Jun 23, 2013Aspirant
ReadyNAS Duo File System Check
Hi all, I recently went away and decided to power down my Duo. I loaded RAIDar v4.3.4 and logged on to my Duo and powered it down, all went O.K with no errors. When I can home I loaded RAIDar and...
Jun 25, 2013Guru - Experienced User
OS reinstall will reinstall the OS on the disk OS partition. :o It will also reset the admin password to the factory default value ("netgear1" for the duo v1), and reset the IP configuration to DHCP.
Other settings and your data should not be affected. However, it is always best to have a backup... While you have the disks connected to a PC for diagnostics, you can try the disk utility I linked earlier.
