ollydrew
Jan 18, 2017Aspirant
ReadyNAS Duo RND2110 v2 "System is starting up..." blue light blinking
I have a ReadyNAS Duo RND2110 v2 with a single Seagate Barracuda 1TB drive in it. When I start the NAS, RAIDar briefly shows: Model: ReadyNAS Duo Name: ESMENAS Status: Healthy Firmware: 4.1.14...
ollydrew
Jan 23, 2017Aspirant
Hi StephenB,
The enclosure arrived and I connected the installed HDD to an old Windows 7 laptop. Windows didn't detect the disk (it didn't appear in My Computer). I downloaded Seatools, which seemed to partially recognise that it was a USB attached disk, but it couldn't determine the model number or serial number. It passed a disk self test but failed both the short and long generic tests. After that each time I disconnected / re-connected the drive (trying different USB ports on the laptop, then Windows kept saying 'USB device was not detected' and in Windows device manager, it appeared as a generic device with an exclamation mark next to it. I wondered if using a newer laptop might help, so I am now using a Windows 10 machine.
With Windows 10, at first there was no difference - Windows still didn't detect the drive, and device manager showed me that the device wasn't installed properly, but eventually, it installed the driver, and it appeared in device manager with no exclamation mark. It still doesn't appear in My Computer though, so I can't simply double click on it, and start exploring files (that would be too easy right?!) So I ran Seatools again, and similalrly, it passes the disk self test, but fails both short and long generic tests.
--------------- SeaTools for Windows v1.4.0.4 ---------------
23/01/2017 19:33:10
Model: 28AS
Serial: j337
Firmware: Unknown
Short DST - Started 23/01/2017 19:33:10
Short DST - Pass 23/01/2017 19:34:13
Identify - Started 23/01/2017 22:11:52
Short Generic - Started 23/01/2017 22:12:08
Short Generic - FAIL 23/01/2017 22:12:41
SeaTools Test Code:
Long Generic - Started 23/01/2017 22:13:36
Long Generic - FAIL 23/01/2017 22:14:09
SeaTools Test Code:
Short DST - Started 23/01/2017 22:14:52
Short DST - Pass 23/01/2017 22:15:55
Next I tried R Linux for Windows. The disk is detected by R Linux, but only as a disk of 7.87GB. I started a scan of the disk, but it looks pretty bad and it's onl been running for 15 mins or so. Am I right in saying that it thinks it's going to take 1 month and 12 days to comeplete the scan?!
Cheers
Olly
- StephenBJan 23, 2017Guru - Experienced User
It looks to me like the disk has failed, so I don't think you'll be able to get any data off of it.
