viperhansa's avatar
viperhansa
Virtuoso
Jan 28, 2018
My system volume is filling up with files "chunk-000xxx"
As stated in Subject.
My md0 went from stable 38-45% to 67% over night.
Did an mount on the system volume and checked and found lots och files named chunk-00001 and so on.
Is it safe to delete those files?
Can anyone point me in the correct way so i maybe can find the issue?
Or do i need to purchase a support ticket for this?
It's an old legacy pro busissinies 6 running os 6.9.2.
regards
// Hans
  • StephenB's avatar
    Jan 29, 2018
    wrote:
    Can i remove those chunk files since they are old dates?
    Yes.
    Second: i forgot how to access disktests and will my data be altered or destroyed if i run them?
    Click on the settings wheel for the volume (on the volume tab).  The tests aren't destructive (unless of course disks fail when they are run).
    There are several maintenance functions in there (defrag, balance, scrub, disk test).  You might consider setting up a regular schedule to run them.  I run each of them once every 3 months.
  • StephenB's avatar
    As you know, this combination is not supported, so you will not be able to use paid support.
    I suspect the system is finding some corruption in the btrfs filesystem.  If you don't have a backup, you should definitely make one.
    It might also be wise to test the disks - either using the built-in disk test, or by connecting them to a windows PC and using vendor tools (lifeguard for western digital, seatools for seagate).
    • viperhansa's avatar
      viperhansa
      Virtuoso
      Thanks for the answer.
      Edit:
      Checked the smart info on all drives and that looked ok to me:
      Device: sda
      Controller: 0
      Channel: 0
      Model: WDC WD40EFRX-68N32N0
      Serial: WD-WCC7K7PZ7DY8
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      PoolHostId: 33ea52d3
      Health data
      ATA Error Count: 0
      Reallocated Sectors: 0
      Reallocation Events: 0
      Spin Retry Count: 0
      Current Pending Sector Count: 0
      Uncorrectable Sector Count: 0
      Temperature: 35
      Start/Stop Count: 66
      Power-On Hours: 4318
      Power Cycle Count: 17
      Load Cycle Count: 61
      Device: sdb
      Controller: 0
      Channel: 1
      Serial: WD-WCC7K2EFJXUF
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      Health data
      ATA Error Count: 0
      Spin Retry Count: 0
      Temperature: 36
      Start/Stop Count: 77
      Power-On Hours: 4301
      Power Cycle Count: 16
      Load Cycle Count: 72
      Device: sdc
      Controller: 0
      Channel: 2
      Serial: WD-WCC7K0XY95Y2
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      Health data
      ATA Error Count: 0
      Spin Retry Count: 0
      Temperature: 35
      Start/Stop Count: 76
      Power-On Hours: 4300
      Power Cycle Count: 15
      Load Cycle Count: 71
      Device: sdd
      Controller: 0
      Channel: 3
      Serial: WD-WCC7K5ZRZUCT
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      Health data
      ATA Error Count: 0
      Spin Retry Count: 0
      Temperature: 36
      Start/Stop Count: 74
      Power-On Hours: 4275
      Load Cycle Count: 68
      Device: sde
      Controller: 0
      Channel: 4
      Serial: WD-WCC7K2JCKHP7
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      Health data
      ATA Error Count: 0
      Spin Retry Count: 0
      Temperature: 37
      Power-On Hours: 2759
      Power Cycle Count: 11
      Load Cycle Count: 59
      Device: sdf
      Controller: 0
      Channel: 5
      Serial: WD-WCC7K1UF7A0C
      Firmware: 82.00A82
      Class: SATA
      RPM: 5400
      Sectors: 7814037168
      Pool: data
      PoolType: RAID 5
      PoolState: 1
      Health data
      ATA Error Count: 0
      Spin Retry Count: 0
      Temperature: 36
      Power-On Hours: 2746
      Power Cycle Count: 9
      Load Cycle Count: 63
      // Hans
      • StephenB's avatar
        Yes.
ProSupport for Business
