tekngolong
Feb 25, 2015Aspirant
Readynas Duo V1 intermittent issues
Hello, I've had my ReadyNAS Duo V1 (RND2175) for about 5 years now [current Raidiator = 4.1.14, current Raidar = 4.3.8], which has been working perfectly until recently, when I started to receive e...
tekngolong
Feb 26, 2015Aspirant
Hello,
I am using X-RAID. I tried removing Disk 2, but the Duo still has the same behavior. Actually, upon removing Disk 2, the Disk 2 light in Raidar continuously blinks - I understand this is normal if it was expecting a second hard drive, but is there a setting that must be changed if you want to operate with only one hard drive? In any case, please advise on the intermittent issues persisting despite having removed Disk 2. Thanks!
