Eorlund
Mar 06, 2016Aspirant
ReadyNAS Duo v1 will not connect to LAN - Faulty NIC ?
Hi, It seems I'm having some issues with connecting my ReadyNAS Duo to my new home-network and I'm at a loss as to why this is. Here is what happens; when I connect my ReadyNAS to my Zyxel modemr...
Eorlund
Mar 07, 2016Aspirant
If I change my PC's IP then I can get direct accsess to the contents via the file explorer.
- StephenBMar 07, 2016Guru - Experienced User
Eorlund wrote:
If I change my PC's IP then I can get direct accsess to the contents via the file explorer.Then begin by backing up all the data on the NAS. Teracopy is a useful utility for that, because it can verify the copy.
After the data is backed up you could try an OS reinstall.
