Lucos
Sep 29, 2015Aspirant
ReadyNas Duo V2 - After restart, nothing works
Hi guys,
After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard).
I perform an OS reinstall by boot menu, but nothing changes.
I tested open ports from my Neywork, only telnet port (23) is open. I tried to connect, but i can't find the credentials...
I don't know what to do.
I think about perform a factory boot, but I don't want to loose my data, and don't have nothing to backup it for the moment.
Someone can help me ?
Thanks
Lucos
- vandermerweMaster
Read this guide and tell us whether this is in fact a v2 or a v1:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Alternatively do you know what firmware was running?
When did you buy the device?
Which lights are on on the nas?
Does raidar see the nas?
Did you receive any messages about disk errors?
You say you have tried ssh access, how did you test ssh access?
What disks are in? One of the things you will need to do is to power down and test the disks using vendor tools on a PC.
- LucosAspirant
Hi vandermerwe,
Thanks for your answer.
It's a ReadyNas Duo v2 (I verified with the guide you sent me).
The firmware version is RAIDiator-arm-5.3.10 (I found the last System Update Status email, from 2014/12/08).
The power button and Disk 1 led are on.
Raidar don't see the nas.
I didn't recieve any messages about disk errors
For ssh, i made a mistake. It could not work has i desinstall SSH add-on few month ago. But 22 port is not open.
There's just one disk. WD Green - 3,5'' 2000 Go - IntelliPower - 64 Mo - SATA III 6 Gb/s
What do you mean by "test the disks using vendor tools on a PC" ? Test the disk with an external usb hard drive box ? I don't have one at home ...
Lucos
- DaneANETGEAR Employee Retired
Hi Lucos,
I just want to share this link below where you can download the Windows version of the Data LifeGuard Diagnostics:
http://support.wdc.com/downloads.aspx?lang=en
DaneA
NETGEAR Community Team
