TheJesterJill
Apr 22, 2015Aspirant
ReadyNAs Duo v2 - does Factory Reset on every boot
Hello everyone, I have a ReadyNAS Duo v2 that I bought used late last year. It worked flawlessly until recently when I had to change the disks. Long story short; I have 2 X 2TB WD20EFRX (Red) disks...
RX
Apr 22, 2015Luminary
What if you try to perform OS reinstall then check if same problem will occur: http://kb.netgear.com/app/answers/detail/a_id/21104
