TheJesterJill
Apr 22, 2015Aspirant
ReadyNAs Duo v2 - does Factory Reset on every boot
Hello everyone, I have a ReadyNAS Duo v2 that I bought used late last year. It worked flawlessly until recently when I had to change the disks. Long story short; I have 2 X 2TB WD20EFRX (Red) disks...
hackin8
May 11, 2015Aspirant
Have owned Readynas for several years, with no issues. Just got an additional NV+ V2 which wants to factory reset on every boot. Having checked the forum it seems it may relate to one of the disks being locked?
Is there a way to resolve this without having to take each disk out and "unlock" it using a PC?
Just to be clear - I have now done a complete factory reset twice, which I thought would unlock the disks? Each time everything seems to work fine - (taking 24 hours for a re-sync) and the NAS works perfectly. If I then shut it down and restart - it again wants to do a factory reset.
Thanks
Thanks
