TheJesterJill
Apr 22, 2015Aspirant
ReadyNAs Duo v2 - does Factory Reset on every boot
Hello everyone, I have a ReadyNAS Duo v2 that I bought used late last year. It worked flawlessly until recently when I had to change the disks. Long story short; I have 2 X 2TB WD20EFRX (Red) disks...
mdgm-ntgr
May 11, 2015NETGEAR Employee Retired
Your disks are now unlocked. The disks are locked when you start a factory default with the secure erase option. If you abort the factory reset before the secure erase completes the disks are not unlocked.
One solution is to manually do another factory default with secure erase and not abort it.
I have manually unlocked your four disks, so I would advise against doing a secure erase this time.
