theboyroy
Feb 28, 2015Aspirant
ReadyNAS Duo v2 - no disks detected
Hi there I have a Netgear ReadyNAS Duo (RND2000 v2) that is about 2 years old and has worked well up until now. When I turn it on, the LED lights flash 3 times quickly and then twice slowly (code for...
vandermerwe
Feb 28, 2015Master
That model number is a v2 , however you are using the boot menu method for a v1. First check your model using this:
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If it's a v2 , then use the boot menu instructions in the manual:
http://www.readynas.com/download/docume ... ept-11.pdf
Also, check all the disks using vendor tools.
You had backed up your data, or do you need to try to access the volume again?
