ColonelPanik
Dec 14, 2011Aspirant
ReadyNAS Duo V2 - USB 3.0 Devices Only Work @ USB 2.0 Speeds
I've read through the forums and I understand this device was just released last month but having big problems/reservations with this unit. There basically is no HCL for USB storage on the Duo V2. All I can find is a link that takes me to a forum of people posting issues. Nothing relevant in the Performance board either. I'm using Seagate 2TB Expansion USB3.0 drives. I have 4 & hoped to connect to this via a powered USB 3.0 hub. All the drives are powered. I removed the hub from the equation to make sure it couldn't be the culprit. I get horrible USB 2.0 speeds between a 5400rpm SATA 500gb Seagate I have in the Duo V2 and the Expansion 2TB 3.0 - basically 24-26 MB/s. That's in both directions via cp command through ssh and using Win explorer on other systems. Those are the same results I get when connecting the USB3.0 drives to USB2.0 ports on other systems (Ubuntu on Intel NAS and Win7 X64 Pro). I do not believe USB3.0 is enabled or there is a hardware conflict not showing up in any system logs on the Duo V2.
On transfers of the same test files (varying sizes from 250mb to 4gb) from my existing NAS over gigabit ethernet I get 60MB/s to internal Duo V2 drive(older Seagate) and USB2.0 speeds to the 2TB Expansion drive (via win explorer shares.) I get between 65-85MB/s copying the same files from the existing NAS to a Win7 x64 Core2Duo system over the same network with other traffic present. There is no Performance tab in the V2 web mgmt interface. I would go to the RND2000-200NAS support page but there isn't one. I have the hardware and software manuals and there is nothing about USB 3.0 performance in those.
Is anyone getting real USB 3.0 speeds from the rear ports on the V2? Is there a firmware update looming for this like with other units?
External drive in use - Seagate 2TB Expansion Desktop Drive Model#STAY2000102
- ColonelPanikAspirantOk so I dove into the kernel log and have figured out the problem. The kernel in use in 5.3.2 is pretty antiquated -2.6.31.8. It's likely missing many of the USB 3.0 patches put out since the current stable is 3.1.5. Not sure if you guys have been applying patches for certain drivers or not. You can see here in the changelog for 2.6.32.13, Sarah - the woman in charge of USB support referencing the improperly set context field bug which may apply to this situation looking at the error in my log. There are also some issues with certain hardware not generating MSI interrupts which was patched on all stable kernels back to 2.6.36. A quick search on Google shows that most folks with these problems experience intermittent connectivity and slow read/write speeds. These are the same symptoms I've been having with my USB3.0 hub - a Syba SDHUB20058, an external SATA->USB 2.0 dock and the Seagate drives. I hope you guys will investigate or at least bring your the kernel current or more current so that some of these patches for USB 3.0 support can be included. Not sure what types of size constraints you guys have since I know you're dealing with a limited amount of space. If you are unable or unwilling to address this could you possibly point me to your build tools for the Duo V2 firmware so that I can compile my own kernel and attempt to resolve this? All I really want is USB 3.0 support. 120MB/s and I won't give a damn if anyone ports over whatever addons.
Thanks in advance for any help you can provide.
A few links for general reference of the issue.
http://ftp.sunet.se/pub/Linux/kernels/v2.6/ChangeLog-2.6.32.13
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=f5182b4155b9d686c5540a6822486400e34ddd98
kern.logDec 14 08:14:31 Nucleus kernel: klogd 1.5.0#6, log source = /proc/kmsg started.
Dec 14 08:14:31 Nucleus kernel: Linux version 2.6.31.8.duov2 (root@NSBU-NJ) (gcc version 4.3.2 (sdk3.2rc1-ct-ng-1.4.1) ) #1 Mon Sep 5 19:02:33 HKT 2011
Dec 14 08:14:31 Nucleus kernel: CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
Dec 14 08:14:31 Nucleus kernel: CPU: VIVT data cache, VIVT instruction cache
Dec 14 08:14:31 Nucleus kernel: Machine: Feroceon-KW
Dec 14 08:14:31 Nucleus kernel: Using UBoot passing parameters structure
Dec 14 08:14:31 Nucleus kernel: Memory policy: ECC disabled, Data cache writeback
Dec 14 08:14:31 Nucleus kernel: On node 0 totalpages: 65536
Dec 14 08:14:31 Nucleus kernel: free_area_init_node: node 0, pgdat c0680664, node_mem_map c06e6000
Dec 14 08:14:31 Nucleus kernel: Normal zone: 512 pages used for memmap
Dec 14 08:14:31 Nucleus kernel: Normal zone: 0 pages reserved
Dec 14 08:14:31 Nucleus kernel: Normal zone: 65024 pages, LIFO batch:15
Dec 14 08:14:31 Nucleus kernel: Built 1 zonelists in Zone order, mobility grouping off. Total pages: 65024
Dec 14 08:14:31 Nucleus kernel: Kernel command line: console=ttyS0,115200 reason=normal mtdparts=nand_mtd:0x180000@0(u-boot),0x20000@0x180000(u-boot-env),0x600000@0x200000(uImage),0x1000000@0x800000(minirootfs),0x6800000@0x1800000(jffs2);
Dec 14 08:14:31 Nucleus kernel: PID hash table entries: 1024 (order: 10, 4096 bytes)
Dec 14 08:14:31 Nucleus kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 14 08:14:31 Nucleus kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 14 08:14:31 Nucleus kernel: Memory: 256MB = 256MB total
Dec 14 08:14:31 Nucleus kernel: Memory: 242176KB available (6112K code, 622K data, 128K init, 0K highmem)
Dec 14 08:14:31 Nucleus kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Dec 14 08:14:31 Nucleus kernel: NR_IRQS:128
Dec 14 08:14:31 Nucleus kernel: Console: colour dummy device 80x30
Dec 14 08:14:31 Nucleus kernel: Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Dec 14 08:14:31 Nucleus kernel: Mount-cache hash table entries: 512
Dec 14 08:14:31 Nucleus kernel: CPU: Testing write buffer coherency: ok
Dec 14 08:14:31 Nucleus kernel: xor: measuring software checksum speed
Dec 14 08:14:31 Nucleus kernel: arm4regs : 1401.600 MB/sec
Dec 14 08:14:31 Nucleus kernel: 8regs : 1103.200 MB/sec
Dec 14 08:14:31 Nucleus kernel: 32regs : 1237.200 MB/sec
Dec 14 08:14:31 Nucleus kernel: xor: using function: arm4regs (1401.600 MB/sec)
Dec 14 08:14:31 Nucleus kernel: NET: Registered protocol family 16
Dec 14 08:14:31 Nucleus kernel: Feroceon L2: Enabling L2
Dec 14 08:14:31 Nucleus kernel: Feroceon L2: Cache support initialised.
Dec 14 08:14:31 Nucleus kernel: CPU Interface
Dec 14 08:14:31 Nucleus kernel: -------------
Dec 14 08:14:31 Nucleus kernel: SDRAM_CS0 ....base 00000000, size 256MB
Dec 14 08:14:31 Nucleus kernel: SDRAM_CS1 ....disable
Dec 14 08:14:31 Nucleus kernel: SDRAM_CS2 ....disable
Dec 14 08:14:31 Nucleus kernel: SDRAM_CS3 ....disable
Dec 14 08:14:31 Nucleus kernel: PEX0_MEM ....base e0000000, size 128MB
Dec 14 08:14:31 Nucleus kernel: PEX0_IO ....base f2000000, size 1MB
Dec 14 08:14:31 Nucleus kernel: PEX1_MEM ....base e8000000, size 128MB
Dec 14 08:14:31 Nucleus kernel: PEX1_IO ....base f2100000, size 1MB
Dec 14 08:14:31 Nucleus kernel: INTER_REGS ....base f1000000, size 1MB
Dec 14 08:14:31 Nucleus kernel: NFLASH_CS ....base fa000000, size 2MB
Dec 14 08:14:31 Nucleus kernel: SPI_CS ....base f4000000, size 16MB
Dec 14 08:14:31 Nucleus kernel: BOOT_ROM_CS ....no such
Dec 14 08:14:31 Nucleus kernel: DEV_BOOTCS ....no such
Dec 14 08:14:31 Nucleus kernel: CRYPT_ENG ....base f0000000, size 2MB
Dec 14 08:14:31 Nucleus kernel: Marvell Development Board (LSP Version KW_LSP_5.1.3_patch18)-- DB-88F6282A-BP Soc: MV88F6282 Rev 1 LE
Dec 14 08:14:31 Nucleus kernel: Detected Tclk 200000000 and SysClk 533333333
Dec 14 08:14:31 Nucleus kernel: MV Buttons Device Load
Dec 14 08:14:31 Nucleus kernel: Marvell USB EHCI Host controller #0: c8002cc0
Dec 14 08:14:31 Nucleus kernel: PEX0 interface detected Link X1
Dec 14 08:14:31 Nucleus kernel: PEX1 interface detected no Link.
Dec 14 08:14:31 Nucleus kernel: PCI: bus0: Fast back to back transfers disabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:01:01.0: reg 10 64bit mmio: [0x40000000-0x40001fff]
Dec 14 08:14:31 Nucleus kernel: pci 0000:01:01.0: PME# supported from D0 D3hot D3cold
Dec 14 08:14:31 Nucleus kernel: pci 0000:01:01.0: PME# disabled
Dec 14 08:14:31 Nucleus kernel: PCI: bus1: Fast back to back transfers disabled
Dec 14 08:14:31 Nucleus kernel: PCI: bus2: Fast back to back transfers disabled
Dec 14 08:14:31 Nucleus kernel: PCI: bus3: Fast back to back transfers enabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:02:01.0: PCI bridge, secondary bus 0000:03
Dec 14 08:14:31 Nucleus kernel: pci 0000:02:01.0: IO window: disabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:02:01.0: MEM window: disabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:02:01.0: PREFETCH window: disabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
Dec 14 08:14:31 Nucleus kernel: pci 0000:00:01.0: IO window: disabled
Dec 14 08:14:31 Nucleus kernel: pci 0000:00:01.0: MEM window: 0xe0000000-0xe00fffff
Dec 14 08:14:31 Nucleus kernel: pci 0000:00:01.0: PREFETCH window: disabled
Dec 14 08:14:31 Nucleus kernel: bio: create slab <bio-0> at 0
Dec 14 08:14:31 Nucleus kernel: SCSI subsystem initialized
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver usbfs
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver hub
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new device driver usb
Dec 14 08:14:31 Nucleus kernel: raid6: int32x1 123 MB/s
Dec 14 08:14:31 Nucleus kernel: raid6: int32x2 158 MB/s
Dec 14 08:14:31 Nucleus kernel: raid6: int32x4 173 MB/s
Dec 14 08:14:31 Nucleus kernel: raid6: int32x8 132 MB/s
Dec 14 08:14:31 Nucleus kernel: raid6: using algorithm int32x4 (173 MB/s)
Dec 14 08:14:31 Nucleus kernel: NET: Registered protocol family 2
Dec 14 08:14:31 Nucleus kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 14 08:14:31 Nucleus kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Dec 14 08:14:31 Nucleus kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Dec 14 08:14:31 Nucleus kernel: TCP: Hash tables configured (established 8192 bind 8192)
Dec 14 08:14:31 Nucleus kernel: TCP reno registered
Dec 14 08:14:31 Nucleus kernel: Unpacking initramfs...
Dec 14 08:14:31 Nucleus kernel: Freeing initrd memory: 4268K
Dec 14 08:14:31 Nucleus kernel: rtc mv_rtc: rtc core: registered kw-rtc as rtc0
Dec 14 08:14:31 Nucleus kernel: RTC registered
Dec 14 08:14:31 Nucleus kernel: cpufreq: Init kirkwood cpufreq driver
Dec 14 08:14:31 Nucleus kernel: cpufreq: High frequency: 1600000KHz - Low frequency: 533333KHz
Dec 14 08:14:31 Nucleus kernel: cpufreq: Setting CPU Frequency to 1600000 KHz
Dec 14 08:14:31 Nucleus kernel: cpufreq: Setting PowerSaveState to off
Dec 14 08:14:31 Nucleus kernel: XOR registered 4 channels
Dec 14 08:14:31 Nucleus kernel: XOR 2nd invalidate WA enabled
Dec 14 08:14:31 Nucleus kernel: mvCesaInit: sessions=640, queue=64, pSram=f0000000
Dec 14 08:14:31 Nucleus kernel: Warning: TS unit is powered off.
Dec 14 08:14:31 Nucleus kernel: MV Buttons Driver Load
Dec 14 08:14:31 Nucleus kernel: VFS: Disk quotas dquot_6.5.2
Dec 14 08:14:31 Nucleus kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Dec 14 08:14:31 Nucleus kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Dec 14 08:14:31 Nucleus kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Dec 14 08:14:31 Nucleus kernel: fuse init (API version 7.12)
Dec 14 08:14:31 Nucleus kernel: msgmni has been set to 481
Dec 14 08:14:31 Nucleus kernel: alg: No test for cipher_null (cipher_null-generic)
Dec 14 08:14:31 Nucleus kernel: alg: No test for ecb(cipher_null) (ecb-cipher_null)
Dec 14 08:14:31 Nucleus kernel: alg: No test for digest_null (digest_null-generic)
Dec 14 08:14:31 Nucleus kernel: alg: No test for compress_null (compress_null-generic)
Dec 14 08:14:31 Nucleus kernel: alg: No test for stdrng (krng)
Dec 14 08:14:31 Nucleus kernel: alg: No test for hmac(digest_null) (hmac(digest_null-generic))
Dec 14 08:14:31 Nucleus kernel: async_tx: api initialized (sync-only)
Dec 14 08:14:31 Nucleus kernel: io scheduler noop registered
Dec 14 08:14:31 Nucleus kernel: io scheduler anticipatory registered
Dec 14 08:14:31 Nucleus kernel: io scheduler deadline registered
Dec 14 08:14:31 Nucleus kernel: io scheduler cfq registered (default)
Dec 14 08:14:31 Nucleus kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Dec 14 08:14:31 Nucleus kernel: serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
Dec 14 08:14:31 Nucleus kernel: console [ttyS0] enabled
Dec 14 08:14:31 Nucleus kernel: loop: module loaded
Dec 14 08:14:31 Nucleus kernel: Integrated Sata device found
Dec 14 08:14:31 Nucleus kernel: IRQ 21/mvSata: IRQF_DISABLED is not guaranteed on shared IRQs
Dec 14 08:14:31 Nucleus kernel: scsi0 : Marvell SCSI to SATA adapter
Dec 14 08:14:31 Nucleus kernel: scsi1 : Marvell SCSI to SATA adapter
Dec 14 08:14:31 Nucleus kernel: Loading Marvell Ethernet Driver:
Dec 14 08:14:31 Nucleus kernel: o Cached descriptors in DRAM
Dec 14 08:14:31 Nucleus kernel: o DRAM SW cache-coherency
Dec 14 08:14:31 Nucleus kernel: o 1 Giga ports supported
Dec 14 08:14:31 Nucleus kernel: o Multi RX Queue support - 4 RX queues
Dec 14 08:14:31 Nucleus kernel: o Multi TX Queue support - 2 TX Queues
Dec 14 08:14:31 Nucleus kernel: o TCP segmentation offload (TSO) supported
Dec 14 08:14:31 Nucleus kernel: o Large Receive offload (LRO) supported
Dec 14 08:14:31 Nucleus kernel: o Receive checksum offload supported
Dec 14 08:14:31 Nucleus kernel: o Transmit checksum offload supported
Dec 14 08:14:31 Nucleus kernel: o Network Fast Processing (Routing) supported - (Disabled)
Dec 14 08:14:31 Nucleus kernel: o Driver ERROR statistics enabled
Dec 14 08:14:31 Nucleus kernel: o Driver INFO statistics enabled
Dec 14 08:14:31 Nucleus kernel: o Proc tool API enabled
Dec 14 08:14:31 Nucleus kernel: o SKB Reuse supported - (Enabled)
Dec 14 08:14:31 Nucleus kernel: o SKB Recycle supported - (Enabled)
Dec 14 08:14:31 Nucleus kernel: o Gateway support enabled
Dec 14 08:14:31 Nucleus kernel: o Using Marvell Header Mode
Dec 14 08:14:31 Nucleus kernel: o L2 IGMP support
Dec 14 08:14:31 Nucleus kernel: o Rx descripors: q0=128 q1=128 q2=128 q3=128
Dec 14 08:14:31 Nucleus kernel: o Tx descripors: q0=532 q1=532
Dec 14 08:14:31 Nucleus kernel: o Loading network interface(s):
Dec 14 08:14:31 Nucleus kernel: o register under mv88fx_eth platform
Dec 14 08:14:31 Nucleus kernel: o eth0, ifindex = 2, GbE port = 0
Dec 14 08:14:31 Nucleus kernel: mvFpRuleDb (c8d44000): 2048 entries, 8192 bytes
Dec 14 08:14:31 Nucleus kernel: Intel(R) PRO/1000 Network Driver - version 7.3.21-k3-NAPI
Dec 14 08:14:31 Nucleus kernel: Copyright (c) 1999-2006 Intel Corporation.
Dec 14 08:14:31 Nucleus kernel: e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k2
Dec 14 08:14:31 Nucleus kernel: e1000e: Copyright (c) 1999-2008 Intel Corporation.
Dec 14 08:14:31 Nucleus kernel: e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
Dec 14 08:14:31 Nucleus kernel: e100: Copyright(c) 1999-2006 Intel Corporation
Dec 14 08:14:31 Nucleus kernel: tun: Universal TUN/TAP device driver, 1.6
Dec 14 08:14:31 Nucleus kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Dec 14 08:14:31 Nucleus kernel: Using Hamming 1-bit ECC for NAND device
Dec 14 08:14:31 Nucleus kernel: NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
Dec 14 08:14:31 Nucleus kernel: Scanning device for bad blocks
Dec 14 08:14:31 Nucleus kernel: mtd: no mtd-id
Dec 14 08:14:31 Nucleus kernel: 5 cmdlinepart partitions found on MTD device nand_mtd
Dec 14 08:14:31 Nucleus kernel: Using command line partition definition
Dec 14 08:14:31 Nucleus kernel: Creating 5 MTD partitions on "nand_mtd":
Dec 14 08:14:31 Nucleus kernel: 0x000000000000-0x000000180000 : "u-boot"
Dec 14 08:14:31 Nucleus kernel: 0x000000180000-0x0000001a0000 : "u-boot-env"
Dec 14 08:14:31 Nucleus kernel: 0x000000200000-0x000000800000 : "uImage"
Dec 14 08:14:31 Nucleus kernel: 0x000000800000-0x000001800000 : "minirootfs"
Dec 14 08:14:31 Nucleus kernel: 0x000001800000-0x000008000000 : "jffs2"
Dec 14 08:14:31 Nucleus kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 14 08:14:31 Nucleus kernel: ehci_marvell ehci_marvell.70059: Marvell Orion EHCI
Dec 14 08:14:31 Nucleus kernel: ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1
Dec 14 08:14:31 Nucleus kernel: ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
Dec 14 08:14:31 Nucleus kernel: ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
Dec 14 08:14:31 Nucleus kernel: hub 1-0:1.0: USB hub found
Dec 14 08:14:31 Nucleus kernel: hub 1-0:1.0: 1 port detected
Dec 14 08:14:31 Nucleus kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 14 08:14:31 Nucleus kernel: uhci_hcd: USB Universal Host Controller Interface driver
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: xHCI Host Controller
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: new USB bus registered, assigned bus number 2
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: irq 9, io mem 0xe0000000
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: Failed to enable MSI-X
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: failed to allocate MSI entry
Dec 14 08:14:31 Nucleus kernel: xHCI xhci_add_endpoint called for root hub
Dec 14 08:14:31 Nucleus kernel: xHCI xhci_check_bandwidth called for root hub
Dec 14 08:14:31 Nucleus kernel: hub 2-0:1.0: USB hub found
Dec 14 08:14:31 Nucleus kernel: hub 2-0:1.0: 2 ports detected
Dec 14 08:14:31 Nucleus kernel: xhci_hcd 0000:01:01.0: new USB bus registered, assigned bus number 3
Dec 14 08:14:31 Nucleus kernel: hub 3-0:1.0: USB hub found
Dec 14 08:14:31 Nucleus kernel: hub 3-0:1.0: 2 ports detected
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver usblp
Dec 14 08:14:31 Nucleus kernel: Initializing USB Mass Storage driver...
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver usb-storage
Dec 14 08:14:31 Nucleus kernel: USB Mass Storage support registered.
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-datafab
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-freecom
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-jumpshot
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-sddr09
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-sddr55
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver ums-usbat
Dec 14 08:14:31 Nucleus kernel: pwrctl: dev_t_NO. = 0xdd00000, major = 221
Dec 14 08:14:31 Nucleus kernel: USB 3.0 Port Power On, Waiting for 3 seconds
Dec 14 08:14:31 Nucleus kernel: HDD_pwrctl_init
Dec 14 08:14:31 Nucleus kernel: MPP26 High.
Dec 14 08:14:31 Nucleus kernel: MPP28 Low.
Dec 14 08:14:31 Nucleus kernel: Request the irq HDDpwrctrl success.
Dec 14 08:14:31 Nucleus kernel: Just power off HDD(2).
Dec 14 08:14:31 Nucleus kernel: Todo: mknod /dev/buttons c 253 0
Dec 14 08:14:31 Nucleus kernel: scsi 0:0:0:0: Direct-Access Seagate ST3500320AS SD1A PQ: 0 ANSI: 5
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] 0-byte physical blocks
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 10 00
Dec 14 08:14:31 Nucleus kernel: mice: PS/2 mouse device common for all mice
Dec 14 08:14:31 Nucleus kernel: i2c /dev entries driver
Dec 14 08:14:31 Nucleus kernel: md: linear personality registered for level -1
Dec 14 08:14:31 Nucleus kernel: md: raid0 personality registered for level 0
Dec 14 08:14:31 Nucleus kernel: md: raid1 personality registered for level 1
Dec 14 08:14:31 Nucleus kernel: md: raid10 personality registered for level 10
Dec 14 08:14:31 Nucleus kernel: md: raid6 personality registered for level 6
Dec 14 08:14:31 Nucleus kernel: md: raid5 personality registered for level 5
Dec 14 08:14:31 Nucleus kernel: md: raid4 personality registered for level 4
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
Dec 14 08:14:31 Nucleus kernel: device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: [email protected]
Dec 14 08:14:31 Nucleus kernel: Registered led device: backup
Dec 14 08:14:31 Nucleus kernel: sda:
Dec 14 08:14:31 Nucleus kernel: Registered led device: sys
Dec 14 08:14:31 Nucleus kernel: Registered led device: sys_fail
Dec 14 08:14:31 Nucleus kernel: Registered led device: SATA1_act
Dec 14 08:14:31 Nucleus kernel: Registered led device: SATA2_act
Dec 14 08:14:31 Nucleus kernel: Registered led device: power
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver hiddev
Dec 14 08:14:31 Nucleus kernel: usbcore: registered new interface driver usbhid
Dec 14 08:14:31 Nucleus kernel: usbhid: v2.6:USB HID core driver
Dec 14 08:14:31 Nucleus kernel: IPv4 over IPv4 tunneling driver
Dec 14 08:14:31 Nucleus kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 14 08:14:31 Nucleus kernel: TCP bic registered
Dec 14 08:14:31 Nucleus kernel: NET: Registered protocol family 10
Dec 14 08:14:31 Nucleus kernel: lo: Disabled Privacy Extensions
Dec 14 08:14:31 Nucleus kernel: tunl0: Disabled Privacy Extensions
Dec 14 08:14:31 Nucleus kernel: NET: Registered protocol family 17
Dec 14 08:14:31 Nucleus kernel: RPC: Registered udp transport module.
Dec 14 08:14:31 Nucleus kernel: RPC: Registered tcp transport module.
Dec 14 08:14:31 Nucleus kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Dec 14 08:14:31 Nucleus kernel: All bugs added by David S. Miller <[email protected]>
Dec 14 08:14:31 Nucleus kernel: rtc mv_rtc: setting system clock to 2011-12-14 07:59:28 UTC (1323849568)
Dec 14 08:14:31 Nucleus kernel: sda1 sda2 sda3
Dec 14 08:14:31 Nucleus kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 14 08:14:31 Nucleus kernel: Freeing init memory: 128K
Dec 14 08:14:31 Nucleus kernel: armvpd: module license 'Proprietary' taints kernel.
Dec 14 08:14:31 Nucleus kernel: Disabling lock debugging due to kernel taint
Dec 14 08:14:31 Nucleus kernel: ReadyNAS Pro VPD device driver init...
Dec 14 08:14:31 Nucleus kernel: Tuxera NTFS driver 3011.10.19 [Flags: R/W MODULE].
Dec 14 08:14:31 Nucleus kernel: eth0: link down
Dec 14 08:14:31 Nucleus kernel: eth0: started
Dec 14 08:14:31 Nucleus kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 14 08:14:31 Nucleus kernel: md: bind<sda1>
Dec 14 08:14:31 Nucleus kernel: raid1: raid set md0 active with 1 out of 1 mirrors
Dec 14 08:14:31 Nucleus kernel: md0: detected capacity change from 0 to 4293906432
Dec 14 08:14:31 Nucleus kernel: md0: unknown partition table
Dec 14 08:14:31 Nucleus kernel: md: bind<sda2>
Dec 14 08:14:31 Nucleus kernel: raid1: raid set md1 active with 1 out of 1 mirrors
Dec 14 08:14:31 Nucleus kernel: md1: detected capacity change from 0 to 536858624
Dec 14 08:14:31 Nucleus kernel: md1: unknown partition table
Dec 14 08:14:31 Nucleus kernel: md: bind<sda3>
Dec 14 08:14:31 Nucleus kernel: raid0: looking at sda3
Dec 14 08:14:31 Nucleus kernel: raid0: comparing sda3(967329664)
Dec 14 08:14:31 Nucleus kernel: with sda3(967329664)
Dec 14 08:14:31 Nucleus kernel: raid0: END
Dec 14 08:14:31 Nucleus kernel: raid0: ==> UNIQUE
Dec 14 08:14:31 Nucleus kernel: raid0: 1 zones
Dec 14 08:14:31 Nucleus kernel: raid0: FINAL 1 zones
Dec 14 08:14:31 Nucleus kernel: raid0: done.
Dec 14 08:14:31 Nucleus kernel: raid0 : md_size is 967329664 sectors.
Dec 14 08:14:31 Nucleus kernel: ******* md2 configuration *********
Dec 14 08:14:31 Nucleus kernel: zone0=[sda3/]
Dec 14 08:14:31 Nucleus kernel: zone offset=0kb device offset=0kb size=483664832kb
Dec 14 08:14:31 Nucleus kernel: **********************************
Dec 14 08:14:31 Nucleus kernel: md2: detected capacity change from 0 to 495272787968
Dec 14 08:14:31 Nucleus kernel: md2: unknown partition table
Dec 14 08:14:31 Nucleus kernel: kjournald starting. Commit interval 5 seconds
Dec 14 08:14:31 Nucleus kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 14 08:14:31 Nucleus kernel: eth0: link up, full duplex, speed 1 Gbps
Dec 14 08:14:31 Nucleus kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec 14 08:14:31 Nucleus kernel: eth0: no IPv6 routers present
Dec 14 08:14:31 Nucleus kernel: EXT3 FS on md0, internal journal
Dec 14 08:14:31 Nucleus kernel: md: md2 stopped.
Dec 14 08:14:31 Nucleus kernel: md: unbind<sda3>
Dec 14 08:14:31 Nucleus kernel: md: export_rdev(sda3)
Dec 14 08:14:31 Nucleus kernel: md: md1 stopped.
Dec 14 08:14:31 Nucleus kernel: md: unbind<sda2>
Dec 14 08:14:31 Nucleus kernel: md: export_rdev(sda2)
Dec 14 08:14:31 Nucleus kernel: md: md0 stopped.
Dec 14 08:14:31 Nucleus kernel: md: unbind<sda1>
Dec 14 08:14:31 Nucleus kernel: md: export_rdev(sda1)
Dec 14 08:14:31 Nucleus kernel: sda: unknown partition table
Dec 14 08:14:31 Nucleus kernel: sda: sda1 sda2 sda3
Dec 14 08:14:31 Nucleus kernel: Adding 524268k swap on /dev/md1. Priority:-1 extents:1 across:524268k
Dec 14 08:14:31 Nucleus kernel: EXT4-fs (dm-0): barriers enabled
Dec 14 08:14:31 Nucleus kernel: kjournald2 starting: pid 838, dev dm-0:8, commit interval 5 seconds
Dec 14 08:14:31 Nucleus kernel: EXT4-fs (dm-0): internal journal on dm-0:8
Dec 14 08:14:31 Nucleus kernel: EXT4-fs (dm-0): delayed allocation enabled
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: file extents enabled
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: mballoc enabled
Dec 14 08:14:31 Nucleus kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: mballoc: 0 blocks 0 reqs (0 success)
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: mballoc: 0 extents scanned, 0 goal hits, 0 2^N hits, 0 breaks, 0 lost
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: mballoc: 3 generated and it took 0
Dec 14 08:14:31 Nucleus kernel: EXT4-fs: mballoc: 0 preallocated, 0 discarded
Dec 14 08:14:31 Nucleus kernel: udevd version 125 started
Dec 14 08:14:31 Nucleus kernel: kjournald2 starting: pid 1689, dev dm-0:8, commit interval 5 seconds
Dec 14 08:14:31 Nucleus kernel: VFS (dm-0): Writes happened before quota was turned on thus quota information is probably inconsistent. Please run quotacheck(8).
Dec 14 08:14:48 Nucleus kernel: program smartctl.org is using a deprecated SCSI ioctl, please convert it to SG_IO
Dec 14 08:14:56 Nucleus last message repeated 13 times
Dec 14 09:21:11 Nucleus kernel: usb 2-1: new high speed USB device number 2 using xhci_hcd
Dec 14 09:21:12 Nucleus kernel: xhci_hcd 0000:01:01.0: WARN: short transfer on control ep
Dec 14 09:21:12 Nucleus last message repeated 3 times
Dec 14 09:21:12 Nucleus kernel: scsi2 : usb-storage 2-1:1.0
Dec 14 09:21:13 Nucleus kernel: scsi 2:0:0:0: Direct-Access Seagate External SG12 PQ: 0 ANSI: 4
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: [sdb] 3907029164 512-byte logical blocks: (2.00 TB/1.81 TiB)
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: [sdb] Write Protect is off
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: [sdb] Mode Sense: 1c 00 00 00
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: [sdb] Assuming drive cache: write through
Dec 14 09:21:13 Nucleus kernel: sdb: sdb1
Dec 14 09:21:13 Nucleus kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Dec 14 09:21:22 Nucleus kernel: tntfs info: NTFS volume version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Dec 14 09:21:24 Nucleus kernel: xhci_hcd 0000:01:01.0: WARN: Stalled endpoint
Dec 14 09:24:41 Nucleus kernel: Uncached vma cd5f5000 (addr 40988000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:24:41 Nucleus kernel: Uncached vma c13f9108 (addr 40b58000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:24:41 Nucleus kernel: Uncached vma c1275aa8 (addr 40585000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:24:41 Nucleus kernel: Uncached vma cd32e058 (addr 40585000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:24:41 Nucleus kernel: Uncached vma c52d45d8 (addr 40581000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:24:41 Nucleus kernel: Uncached vma cc47a108 (addr 40c37000 flags 080000d5 phy 066a0000) from pid 6400
Dec 14 09:25:16 Nucleus kernel: Uncached vma c13351b8 (addr 40581000 flags 080000d5 phy 066a0000) from pid 6419
Dec 14 09:33:26 Nucleus kernel: Uncached vma c930e948 (addr 40585000 flags 080000d5 phy 066a0000) from pid 6930
Dec 14 09:38:33 Nucleus kernel: usb 2-1: reset high speed USB device number 2 using xhci_hcd
Dec 14 09:38:33 Nucleus kernel: xhci_hcd 0000:01:01.0: WARN: short transfer on control ep
Dec 14 09:38:33 Nucleus kernel: xhci_hcd 0000:01:01.0: xHCI xhci_drop_endpoint called with disabled ep c16bd08c
Dec 14 09:38:33 Nucleus kernel: xhci_hcd 0000:01:01.0: xHCI xhci_drop_endpoint called with disabled ep c16bd060
Dec 14 09:40:04 BillyStrongBoy kernel: klogd 1.5.0#6, log source = /proc/kmsg started.
Dec 14 09:40:04 BillyStrongBoy kernel: Linux version 2.6.31.8.duov2 (root@NSBU-NJ) (gcc version 4.3.2 (sdk3.2rc1-ct-ng-1.4.1) ) #1 Mon Sep 5 19:02:33 HKT 2011
Dec 14 09:40:04 BillyStrongBoy kernel: CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
Dec 14 09:40:04 BillyStrongBoy kernel: CPU: VIVT data cache, VIVT instruction cache
Dec 14 09:40:04 BillyStrongBoy kernel: Machine: Feroceon-KW
Dec 14 09:40:04 BillyStrongBoy kernel: Using UBoot passing parameters structure
Dec 14 09:40:04 BillyStrongBoy kernel: Memory policy: ECC disabled, Data cache writeback
Dec 14 09:40:04 BillyStrongBoy kernel: On node 0 totalpages: 65536
Dec 14 09:40:04 BillyStrongBoy kernel: free_area_init_node: node 0, pgdat c0680664, node_mem_map c06e6000
Dec 14 09:40:04 BillyStrongBoy kernel: Normal zone: 512 pages used for memmap
Dec 14 09:40:04 BillyStrongBoy kernel: Normal zone: 0 pages reserved
Dec 14 09:40:04 BillyStrongBoy kernel: Normal zone: 65024 pages, LIFO batch:15
Dec 14 09:40:04 BillyStrongBoy kernel: Built 1 zonelists in Zone order, mobility grouping off. Total pages: 65024
Dec 14 09:40:04 BillyStrongBoy kernel: Kernel command line: console=ttyS0,115200 reason=normal mtdparts=nand_mtd:0x180000@0(u-boot),0x20000@0x180000(u-boot-env),0x600000@0x200000(uImage),0x1000000@0x800000(minirootfs),0x6800000@0x1800000(jffs2);
Dec 14 09:40:04 BillyStrongBoy kernel: PID hash table entries: 1024 (order: 10, 4096 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: Memory: 256MB = 256MB total
Dec 14 09:40:04 BillyStrongBoy kernel: Memory: 242176KB available (6112K code, 622K data, 128K init, 0K highmem)
Dec 14 09:40:04 BillyStrongBoy kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Dec 14 09:40:04 BillyStrongBoy kernel: NR_IRQS:128
Dec 14 09:40:04 BillyStrongBoy kernel: Console: colour dummy device 80x30
Dec 14 09:40:04 BillyStrongBoy kernel: Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Dec 14 09:40:04 BillyStrongBoy kernel: Mount-cache hash table entries: 512
Dec 14 09:40:04 BillyStrongBoy kernel: CPU: Testing write buffer coherency: ok
Dec 14 09:40:04 BillyStrongBoy kernel: xor: measuring software checksum speed
Dec 14 09:40:04 BillyStrongBoy kernel: arm4regs : 1401.200 MB/sec
Dec 14 09:40:04 BillyStrongBoy kernel: 8regs : 1103.200 MB/sec
Dec 14 09:40:04 BillyStrongBoy kernel: 32regs : 1237.200 MB/sec
Dec 14 09:40:04 BillyStrongBoy kernel: xor: using function: arm4regs (1401.200 MB/sec)
Dec 14 09:40:04 BillyStrongBoy kernel: NET: Registered protocol family 16
Dec 14 09:40:04 BillyStrongBoy kernel: Feroceon L2: Enabling L2
Dec 14 09:40:04 BillyStrongBoy kernel: Feroceon L2: Cache support initialised.
Dec 14 09:40:04 BillyStrongBoy kernel: CPU Interface
Dec 14 09:40:04 BillyStrongBoy kernel: -------------
Dec 14 09:40:04 BillyStrongBoy kernel: SDRAM_CS0 ....base 00000000, size 256MB
Dec 14 09:40:04 BillyStrongBoy kernel: SDRAM_CS1 ....disable
Dec 14 09:40:04 BillyStrongBoy kernel: SDRAM_CS2 ....disable
Dec 14 09:40:04 BillyStrongBoy kernel: SDRAM_CS3 ....disable
Dec 14 09:40:04 BillyStrongBoy kernel: PEX0_MEM ....base e0000000, size 128MB
Dec 14 09:40:04 BillyStrongBoy kernel: PEX0_IO ....base f2000000, size 1MB
Dec 14 09:40:04 BillyStrongBoy kernel: PEX1_MEM ....base e8000000, size 128MB
Dec 14 09:40:04 BillyStrongBoy kernel: PEX1_IO ....base f2100000, size 1MB
Dec 14 09:40:04 BillyStrongBoy kernel: INTER_REGS ....base f1000000, size 1MB
Dec 14 09:40:04 BillyStrongBoy kernel: NFLASH_CS ....base fa000000, size 2MB
Dec 14 09:40:04 BillyStrongBoy kernel: SPI_CS ....base f4000000, size 16MB
Dec 14 09:40:04 BillyStrongBoy kernel: BOOT_ROM_CS ....no such
Dec 14 09:40:04 BillyStrongBoy kernel: DEV_BOOTCS ....no such
Dec 14 09:40:04 BillyStrongBoy kernel: CRYPT_ENG ....base f0000000, size 2MB
Dec 14 09:40:04 BillyStrongBoy kernel: Marvell Development Board (LSP Version KW_LSP_5.1.3_patch18)-- DB-88F6282A-BP Soc: MV88F6282 Rev 1 LE
Dec 14 09:40:04 BillyStrongBoy kernel: Detected Tclk 200000000 and SysClk 533333333
Dec 14 09:40:04 BillyStrongBoy kernel: MV Buttons Device Load
Dec 14 09:40:04 BillyStrongBoy kernel: Marvell USB EHCI Host controller #0: c8002cc0
Dec 14 09:40:04 BillyStrongBoy kernel: PEX0 interface detected Link X1
Dec 14 09:40:04 BillyStrongBoy kernel: PEX1 interface detected no Link.
Dec 14 09:40:04 BillyStrongBoy kernel: PCI: bus0: Fast back to back transfers disabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:01:01.0: reg 10 64bit mmio: [0x40000000-0x40001fff]
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:01:01.0: PME# supported from D0 D3hot D3cold
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:01:01.0: PME# disabled
Dec 14 09:40:04 BillyStrongBoy kernel: PCI: bus1: Fast back to back transfers disabled
Dec 14 09:40:04 BillyStrongBoy kernel: PCI: bus2: Fast back to back transfers disabled
Dec 14 09:40:04 BillyStrongBoy kernel: PCI: bus3: Fast back to back transfers enabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:02:01.0: PCI bridge, secondary bus 0000:03
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:02:01.0: IO window: disabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:02:01.0: MEM window: disabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:02:01.0: PREFETCH window: disabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:00:01.0: IO window: disabled
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:00:01.0: MEM window: 0xe0000000-0xe00fffff
Dec 14 09:40:04 BillyStrongBoy kernel: pci 0000:00:01.0: PREFETCH window: disabled
Dec 14 09:40:04 BillyStrongBoy kernel: bio: create slab <bio-0> at 0
Dec 14 09:40:04 BillyStrongBoy kernel: SCSI subsystem initialized
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver usbfs
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver hub
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new device driver usb
Dec 14 09:40:04 BillyStrongBoy kernel: raid6: int32x1 123 MB/s
Dec 14 09:40:04 BillyStrongBoy kernel: raid6: int32x2 158 MB/s
Dec 14 09:40:04 BillyStrongBoy kernel: raid6: int32x4 174 MB/s
Dec 14 09:40:04 BillyStrongBoy kernel: raid6: int32x8 132 MB/s
Dec 14 09:40:04 BillyStrongBoy kernel: raid6: using algorithm int32x4 (174 MB/s)
Dec 14 09:40:04 BillyStrongBoy kernel: NET: Registered protocol family 2
Dec 14 09:40:04 BillyStrongBoy kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: TCP: Hash tables configured (established 8192 bind 8192)
Dec 14 09:40:04 BillyStrongBoy kernel: TCP reno registered
Dec 14 09:40:04 BillyStrongBoy kernel: Unpacking initramfs...
Dec 14 09:40:04 BillyStrongBoy kernel: Freeing initrd memory: 4268K
Dec 14 09:40:04 BillyStrongBoy kernel: rtc mv_rtc: rtc core: registered kw-rtc as rtc0
Dec 14 09:40:04 BillyStrongBoy kernel: RTC registered
Dec 14 09:40:04 BillyStrongBoy kernel: cpufreq: Init kirkwood cpufreq driver
Dec 14 09:40:04 BillyStrongBoy kernel: cpufreq: High frequency: 1600000KHz - Low frequency: 533333KHz
Dec 14 09:40:04 BillyStrongBoy kernel: cpufreq: Setting CPU Frequency to 1600000 KHz
Dec 14 09:40:04 BillyStrongBoy kernel: cpufreq: Setting PowerSaveState to off
Dec 14 09:40:04 BillyStrongBoy kernel: XOR registered 4 channels
Dec 14 09:40:04 BillyStrongBoy kernel: XOR 2nd invalidate WA enabled
Dec 14 09:40:04 BillyStrongBoy kernel: mvCesaInit: sessions=640, queue=64, pSram=f0000000
Dec 14 09:40:04 BillyStrongBoy kernel: Warning: TS unit is powered off.
Dec 14 09:40:04 BillyStrongBoy kernel: MV Buttons Driver Load
Dec 14 09:40:04 BillyStrongBoy kernel: VFS: Disk quotas dquot_6.5.2
Dec 14 09:40:04 BillyStrongBoy kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Dec 14 09:40:04 BillyStrongBoy kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Dec 14 09:40:04 BillyStrongBoy kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Dec 14 09:40:04 BillyStrongBoy kernel: fuse init (API version 7.12)
Dec 14 09:40:04 BillyStrongBoy kernel: msgmni has been set to 481
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for cipher_null (cipher_null-generic)
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for ecb(cipher_null) (ecb-cipher_null)
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for digest_null (digest_null-generic)
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for compress_null (compress_null-generic)
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for stdrng (krng)
Dec 14 09:40:04 BillyStrongBoy kernel: alg: No test for hmac(digest_null) (hmac(digest_null-generic))
Dec 14 09:40:04 BillyStrongBoy kernel: async_tx: api initialized (sync-only)
Dec 14 09:40:04 BillyStrongBoy kernel: io scheduler noop registered
Dec 14 09:40:04 BillyStrongBoy kernel: io scheduler anticipatory registered
Dec 14 09:40:04 BillyStrongBoy kernel: io scheduler deadline registered
Dec 14 09:40:04 BillyStrongBoy kernel: io scheduler cfq registered (default)
Dec 14 09:40:04 BillyStrongBoy kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Dec 14 09:40:04 BillyStrongBoy kernel: serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
Dec 14 09:40:04 BillyStrongBoy kernel: console [ttyS0] enabled
Dec 14 09:40:04 BillyStrongBoy kernel: loop: module loaded
Dec 14 09:40:04 BillyStrongBoy kernel: Integrated Sata device found
Dec 14 09:40:04 BillyStrongBoy kernel: IRQ 21/mvSata: IRQF_DISABLED is not guaranteed on shared IRQs
Dec 14 09:40:04 BillyStrongBoy kernel: scsi0 : Marvell SCSI to SATA adapter
Dec 14 09:40:04 BillyStrongBoy kernel: scsi1 : Marvell SCSI to SATA adapter
Dec 14 09:40:04 BillyStrongBoy kernel: Loading Marvell Ethernet Driver:
Dec 14 09:40:04 BillyStrongBoy kernel: o Cached descriptors in DRAM
Dec 14 09:40:04 BillyStrongBoy kernel: o DRAM SW cache-coherency
Dec 14 09:40:04 BillyStrongBoy kernel: o 1 Giga ports supported
Dec 14 09:40:04 BillyStrongBoy kernel: o Multi RX Queue support - 4 RX queues
Dec 14 09:40:04 BillyStrongBoy kernel: o Multi TX Queue support - 2 TX Queues
Dec 14 09:40:04 BillyStrongBoy kernel: o TCP segmentation offload (TSO) supported
Dec 14 09:40:04 BillyStrongBoy kernel: o Large Receive offload (LRO) supported
Dec 14 09:40:04 BillyStrongBoy kernel: o Receive checksum offload supported
Dec 14 09:40:04 BillyStrongBoy kernel: o Transmit checksum offload supported
Dec 14 09:40:04 BillyStrongBoy kernel: o Network Fast Processing (Routing) supported - (Disabled)
Dec 14 09:40:04 BillyStrongBoy kernel: o Driver ERROR statistics enabled
Dec 14 09:40:04 BillyStrongBoy kernel: o Driver INFO statistics enabled
Dec 14 09:40:04 BillyStrongBoy kernel: o Proc tool API enabled
Dec 14 09:40:04 BillyStrongBoy kernel: o SKB Reuse supported - (Enabled)
Dec 14 09:40:04 BillyStrongBoy kernel: o SKB Recycle supported - (Enabled)
Dec 14 09:40:04 BillyStrongBoy kernel: o Gateway support enabled
Dec 14 09:40:04 BillyStrongBoy kernel: o Using Marvell Header Mode
Dec 14 09:40:04 BillyStrongBoy kernel: o L2 IGMP support
Dec 14 09:40:04 BillyStrongBoy kernel: o Rx descripors: q0=128 q1=128 q2=128 q3=128
Dec 14 09:40:04 BillyStrongBoy kernel: o Tx descripors: q0=532 q1=532
Dec 14 09:40:04 BillyStrongBoy kernel: o Loading network interface(s):
Dec 14 09:40:04 BillyStrongBoy kernel: o register under mv88fx_eth platform
Dec 14 09:40:04 BillyStrongBoy kernel: o eth0, ifindex = 2, GbE port = 0
Dec 14 09:40:04 BillyStrongBoy kernel: mvFpRuleDb (c8d44000): 2048 entries, 8192 bytes
Dec 14 09:40:04 BillyStrongBoy kernel: Intel(R) PRO/1000 Network Driver - version 7.3.21-k3-NAPI
Dec 14 09:40:04 BillyStrongBoy kernel: Copyright (c) 1999-2006 Intel Corporation.
Dec 14 09:40:04 BillyStrongBoy kernel: e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k2
Dec 14 09:40:04 BillyStrongBoy kernel: e1000e: Copyright (c) 1999-2008 Intel Corporation.
Dec 14 09:40:04 BillyStrongBoy kernel: e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
Dec 14 09:40:04 BillyStrongBoy kernel: e100: Copyright(c) 1999-2006 Intel Corporation
Dec 14 09:40:04 BillyStrongBoy kernel: tun: Universal TUN/TAP device driver, 1.6
Dec 14 09:40:04 BillyStrongBoy kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Dec 14 09:40:04 BillyStrongBoy kernel: Using Hamming 1-bit ECC for NAND device
Dec 14 09:40:04 BillyStrongBoy kernel: NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
Dec 14 09:40:04 BillyStrongBoy kernel: Scanning device for bad blocks
Dec 14 09:40:04 BillyStrongBoy kernel: mtd: no mtd-id
Dec 14 09:40:04 BillyStrongBoy kernel: 5 cmdlinepart partitions found on MTD device nand_mtd
Dec 14 09:40:04 BillyStrongBoy kernel: Using command line partition definition
Dec 14 09:40:04 BillyStrongBoy kernel: Creating 5 MTD partitions on "nand_mtd":
Dec 14 09:40:04 BillyStrongBoy kernel: 0x000000000000-0x000000180000 : "u-boot"
Dec 14 09:40:04 BillyStrongBoy kernel: 0x000000180000-0x0000001a0000 : "u-boot-env"
Dec 14 09:40:04 BillyStrongBoy kernel: 0x000000200000-0x000000800000 : "uImage"
Dec 14 09:40:04 BillyStrongBoy kernel: 0x000000800000-0x000001800000 : "minirootfs"
Dec 14 09:40:04 BillyStrongBoy kernel: 0x000001800000-0x000008000000 : "jffs2"
Dec 14 09:40:04 BillyStrongBoy kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 14 09:40:04 BillyStrongBoy kernel: ehci_marvell ehci_marvell.70059: Marvell Orion EHCI
Dec 14 09:40:04 BillyStrongBoy kernel: ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1
Dec 14 09:40:04 BillyStrongBoy kernel: ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
Dec 14 09:40:04 BillyStrongBoy kernel: ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
Dec 14 09:40:04 BillyStrongBoy kernel: hub 1-0:1.0: USB hub found
Dec 14 09:40:04 BillyStrongBoy kernel: hub 1-0:1.0: 1 port detected
Dec 14 09:40:04 BillyStrongBoy kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 14 09:40:04 BillyStrongBoy kernel: uhci_hcd: USB Universal Host Controller Interface driver
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: xHCI Host Controller
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: new USB bus registered, assigned bus number 2
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: irq 9, io mem 0xe0000000
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: Failed to enable MSI-X
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: failed to allocate MSI entry
Dec 14 09:40:04 BillyStrongBoy kernel: xHCI xhci_add_endpoint called for root hub
Dec 14 09:40:04 BillyStrongBoy kernel: xHCI xhci_check_bandwidth called for root hub
Dec 14 09:40:04 BillyStrongBoy kernel: hub 2-0:1.0: USB hub found
Dec 14 09:40:04 BillyStrongBoy kernel: hub 2-0:1.0: 2 ports detected
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: new USB bus registered, assigned bus number 3
Dec 14 09:40:04 BillyStrongBoy kernel: hub 3-0:1.0: USB hub found
Dec 14 09:40:04 BillyStrongBoy kernel: hub 3-0:1.0: 2 ports detected
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver usblp
Dec 14 09:40:04 BillyStrongBoy kernel: Initializing USB Mass Storage driver...
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver usb-storage
Dec 14 09:40:04 BillyStrongBoy kernel: USB Mass Storage support registered.
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-datafab
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-freecom
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-jumpshot
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-sddr09
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-sddr55
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver ums-usbat
Dec 14 09:40:04 BillyStrongBoy kernel: pwrctl: dev_t_NO. = 0xdd00000, major = 221
Dec 14 09:40:04 BillyStrongBoy kernel: USB 3.0 Port Power On, Waiting for 3 seconds
Dec 14 09:40:04 BillyStrongBoy kernel: HDD_pwrctl_init
Dec 14 09:40:04 BillyStrongBoy kernel: MPP26 High.
Dec 14 09:40:04 BillyStrongBoy kernel: MPP28 Low.
Dec 14 09:40:04 BillyStrongBoy kernel: Request the irq HDDpwrctrl success.
Dec 14 09:40:04 BillyStrongBoy kernel: Just power off HDD(2).
Dec 14 09:40:04 BillyStrongBoy kernel: Todo: mknod /dev/buttons c 253 0
Dec 14 09:40:04 BillyStrongBoy kernel: scsi 0:0:0:0: Direct-Access Seagate ST3500320AS SD1A PQ: 0 ANSI: 5
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] 0-byte physical blocks
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 10 00
Dec 14 09:40:04 BillyStrongBoy kernel: mice: PS/2 mouse device common for all mice
Dec 14 09:40:04 BillyStrongBoy kernel: i2c /dev entries driver
Dec 14 09:40:04 BillyStrongBoy kernel: md: linear personality registered for level -1
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid0 personality registered for level 0
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid1 personality registered for level 1
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid10 personality registered for level 10
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid6 personality registered for level 6
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid5 personality registered for level 5
Dec 14 09:40:04 BillyStrongBoy kernel: md: raid4 personality registered for level 4
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
Dec 14 09:40:04 BillyStrongBoy kernel: device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: [email protected]
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: backup
Dec 14 09:40:04 BillyStrongBoy kernel: sda:
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: sys
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: sys_fail
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: SATA1_act
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: SATA2_act
Dec 14 09:40:04 BillyStrongBoy kernel: Registered led device: power
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver hiddev
Dec 14 09:40:04 BillyStrongBoy kernel: usbcore: registered new interface driver usbhid
Dec 14 09:40:04 BillyStrongBoy kernel: usbhid: v2.6:USB HID core driver
Dec 14 09:40:04 BillyStrongBoy kernel: IPv4 over IPv4 tunneling driver
Dec 14 09:40:04 BillyStrongBoy kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 14 09:40:04 BillyStrongBoy kernel: TCP bic registered
Dec 14 09:40:04 BillyStrongBoy kernel: NET: Registered protocol family 10
Dec 14 09:40:04 BillyStrongBoy kernel: lo: Disabled Privacy Extensions
Dec 14 09:40:04 BillyStrongBoy kernel: tunl0: Disabled Privacy Extensions
Dec 14 09:40:04 BillyStrongBoy kernel: NET: Registered protocol family 17
Dec 14 09:40:04 BillyStrongBoy kernel: RPC: Registered udp transport module.
Dec 14 09:40:04 BillyStrongBoy kernel: RPC: Registered tcp transport module.
Dec 14 09:40:04 BillyStrongBoy kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Dec 14 09:40:04 BillyStrongBoy kernel: All bugs added by David S. Miller <[email protected]>
Dec 14 09:40:04 BillyStrongBoy kernel: rtc mv_rtc: setting system clock to 2011-12-14 09:39:23 UTC (1323855563)
Dec 14 09:40:04 BillyStrongBoy kernel: sda1 sda2 sda3
Dec 14 09:40:04 BillyStrongBoy kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 14 09:40:04 BillyStrongBoy kernel: Freeing init memory: 128K
Dec 14 09:40:04 BillyStrongBoy kernel: armvpd: module license 'Proprietary' taints kernel.
Dec 14 09:40:04 BillyStrongBoy kernel: Disabling lock debugging due to kernel taint
Dec 14 09:40:04 BillyStrongBoy kernel: ReadyNAS Pro VPD device driver init...
Dec 14 09:40:04 BillyStrongBoy kernel: Tuxera NTFS driver 3011.10.19 [Flags: R/W MODULE].
Dec 14 09:40:04 BillyStrongBoy kernel: eth0: link down
Dec 14 09:40:04 BillyStrongBoy kernel: eth0: started
Dec 14 09:40:04 BillyStrongBoy kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 14 09:40:04 BillyStrongBoy kernel: md: bind<sda1>
Dec 14 09:40:04 BillyStrongBoy kernel: raid1: raid set md0 active with 1 out of 1 mirrors
Dec 14 09:40:04 BillyStrongBoy kernel: md0: detected capacity change from 0 to 4293906432
Dec 14 09:40:04 BillyStrongBoy kernel: md0: unknown partition table
Dec 14 09:40:04 BillyStrongBoy kernel: md: bind<sda2>
Dec 14 09:40:04 BillyStrongBoy kernel: raid1: raid set md1 active with 1 out of 1 mirrors
Dec 14 09:40:04 BillyStrongBoy kernel: md1: detected capacity change from 0 to 536858624
Dec 14 09:40:04 BillyStrongBoy kernel: md1: unknown partition table
Dec 14 09:40:04 BillyStrongBoy kernel: md: bind<sda3>
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: looking at sda3
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: comparing sda3(967329664)
Dec 14 09:40:04 BillyStrongBoy kernel: with sda3(967329664)
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: END
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: ==> UNIQUE
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: 1 zones
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: FINAL 1 zones
Dec 14 09:40:04 BillyStrongBoy kernel: raid0: done.
Dec 14 09:40:04 BillyStrongBoy kernel: raid0 : md_size is 967329664 sectors.
Dec 14 09:40:04 BillyStrongBoy kernel: ******* md2 configuration *********
Dec 14 09:40:04 BillyStrongBoy kernel: zone0=[sda3/]
Dec 14 09:40:04 BillyStrongBoy kernel: zone offset=0kb device offset=0kb size=483664832kb
Dec 14 09:40:04 BillyStrongBoy kernel: **********************************
Dec 14 09:40:04 BillyStrongBoy kernel: md2: detected capacity change from 0 to 495272787968
Dec 14 09:40:04 BillyStrongBoy kernel: md2: unknown partition table
Dec 14 09:40:04 BillyStrongBoy kernel: kjournald starting. Commit interval 5 seconds
Dec 14 09:40:04 BillyStrongBoy kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 14 09:40:04 BillyStrongBoy kernel: eth0: link up, full duplex, speed 1 Gbps
Dec 14 09:40:04 BillyStrongBoy kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec 14 09:40:04 BillyStrongBoy kernel: usb 2-1: new high speed USB device number 2 using xhci_hcd
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: WARN: short transfer on control ep
Dec 14 09:40:04 BillyStrongBoy last message repeated 3 times
Dec 14 09:40:04 BillyStrongBoy kernel: scsi2 : usb-storage 2-1:1.0
Dec 14 09:40:04 BillyStrongBoy kernel: scsi 2:0:0:0: Direct-Access Seagate External SG12 PQ: 0 ANSI: 4
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: [sdb] 3907029164 512-byte logical blocks: (2.00 TB/1.81 TiB)
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: [sdb] Write Protect is off
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: [sdb] Mode Sense: 1c 00 00 00
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: [sdb] Assuming drive cache: write through
Dec 14 09:40:04 BillyStrongBoy kernel: sdb: sdb1
Dec 14 09:40:04 BillyStrongBoy kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Dec 14 09:40:04 BillyStrongBoy kernel: eth0: no IPv6 routers present
Dec 14 09:40:04 BillyStrongBoy kernel: EXT3 FS on md0, internal journal
Dec 14 09:40:04 BillyStrongBoy kernel: udevd version 125 started
Dec 14 09:40:04 BillyStrongBoy kernel: tntfs info: NTFS volume version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: WARN: Stalled endpoint
Dec 14 09:40:04 BillyStrongBoy kernel: Adding 524268k swap on /dev/md1. Priority:-1 extents:1 across:524268k
Dec 14 09:40:04 BillyStrongBoy kernel: usb 2-1: reset high speed USB device number 2 using xhci_hcd
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: xHCI xhci_drop_endpoint called with disabled ep c209492c
Dec 14 09:40:04 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: xHCI xhci_drop_endpoint called with disabled ep c2094900
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs (dm-0): barriers enabled
Dec 14 09:40:04 BillyStrongBoy kernel: kjournald2 starting: pid 1548, dev dm-0:8, commit interval 5 seconds
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs (dm-0): internal journal on dm-0:8
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs (dm-0): delayed allocation enabled
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs: file extents enabled
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs: mballoc enabled
Dec 14 09:40:04 BillyStrongBoy kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode
Dec 14 09:40:20 BillyStrongBoy kernel: program smartctl.org is using a deprecated SCSI ioctl, please convert it to SG_IO
Dec 14 09:40:25 BillyStrongBoy last message repeated 7 times
Dec 14 09:40:25 BillyStrongBoy kernel: xhci_hcd 0000:01:01.0: WARN: Stalled endpoint
Dec 14 09:40:25 BillyStrongBoy kernel: program smartctl.org is using a deprecated SCSI ioctl, please convert it to SG_IO
Dec 14 09:41:00 BillyStrongBoy last message repeated 2 times
Dec 14 09:43:59 BillyStrongBoy kernel: eth0: stopped
Dec 14 09:44:02 BillyStrongBoy kernel: eth0: link down
Dec 14 09:44:02 BillyStrongBoy kernel: eth0: started
Dec 14 09:44:02 BillyStrongBoy kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 14 09:44:03 BillyStrongBoy kernel: eth0: link up, full duplex, speed 1 Gbps
Dec 14 09:44:03 BillyStrongBoy kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
- mdgm-ntgrNETGEAR Employee RetiredNetGear does backport patches where it can and does tend to gradually update the kernel over time picking kernels that have proven to be good ones.
USB issues is an area of focus at the moment.
You're not going to get speeds of 120MB/s over USB3. USB is a resource hog. You should get faster speeds than on the front USB 2.0 port but don't expect the impossible. Disk speed, CPU etc. are all limiting factors. - ColonelPanikAspirantI understand I likely won't reach the highest possible speeds but 24MB/s is not what I paid for. I know this is capable of a lot better than that. If you had to give an estimate on how long it'd be before some USB 3.0 patches would be applied what would that be? I understand that even those may not provide a solution for me but just trying to get an idea of how fast or often you guys update. Thanks for the reply.
- mdgm-ntgrNETGEAR Employee RetiredWhat speeds do you get on the front USB2 port compared with what you get on the USB 3 ports on the back? Are the speeds faster on the USB3 port?
When gigabit NASes first came out they were a bit faster over gigabit than they would be over 100 megabit. The extra speed was enough to justify the inclusion of a gigabit port despite the fact the NASes couldn't get remotely close to the theoretical limitation of the standard.
I don't work for NetGear. I'm just a beta tester. I don't know what patches they have applied. If and only if the patches are open source, then you could look to the GPL (http://www.readynas.com/gpl) to see what's included.
What filesystem is on your USB disk? Have you tried different filesystems (e.g. NTFS and EXT3 - I would suggest trying both of these)?
Firmware updates very roughly tend to come every few months or so, I think. It does vary a bit. However often in-between production firmwares there are public betas. There hasn't been any public betas of ARM firmware yet, but there may well be at some point in the future. We'll have to wait and see. - ColonelPanikAspirantInteresting - USB 2.0 port is in the 20's MB/s read & write. The better news is I'm now averaging 57 MB/s across the network and from internal SATA (on a slow drive) to both USB 3.0 ports using different drives. It's slightly slower between USB 3.0 ports - 44 MB/s. I have no idea why the rates are improving. I will test again after the next reboot and see if it holds up. Those speeds are good enough for me. Friday I will test out the new unit and see how it performs. Very weird. Never heard of a break-in period for a NAS.
Really appreciate the responses, especially since you aren't Netgear staff. - mdgm-ntgrNETGEAR Employee RetiredThat is odd, but good.
Perhaps a few reboots after the update to 5.3.2 are needed to get the benefits of the improvements in that firmware in regards to USB drives? - ColonelPanikAspirantMore weirdness...
After reboot none of the drives are mounted. No matter what I try or how I reboot no USB 3 devices work after a reboot unless they're in the USB 2.0 port. Power cycling the Duo V2 I get different results. Sometimes the drives are automatically seen and other times they aren't. If they aren't, a power cycle of the USB 3.0 drive and it is mounted again. If you have to disconnect the USB 3.0 drive from the Duo you have to power cycle it to allow for automounting again.
Tried EXT3 and it works as well as NTFS. Definitely not any better with throughput. Results were toward the bottom of the NTFS averages but still better than USB 2.0. - ColonelPanikAspirant
mdgm wrote: That is odd, but good.
Possibly. Maybe it's that plus the buggy interaction between the drivers and the onboard USB 3 controller. There's still no way to know whether or not a working external USB 3.0 disk will be automatically mounted after a power cycle. I do know that it will be mountable though and work at the better speeds. I know it definitely won't work after a restart/reboot. So many variations I'm hoping this unit has a defective controller. - ColonelPanikAspirantThe new unit is not much better. This is a xhci_hcd driver issue.
After initial setup on the new V2 I see the following in dmesgxhci_hcd 0000:01:01.0: xHCI Host Controller
This is what you see in dmesg on the new Duo V2 when attaching a USB 3.0 drive.xhci_hcd 0000:01:01.0: Timeout while waiting for a slot
hub 3-0:1.0: couldn't allocate port 2 usb_device
hub 3-0:1.0: couldn't allocate port 1 usb_device
The exact same problem is present in various distros most of which were resolved in the first or second quarter of 2011. I'd be able to work with it more if the driver was a module. As is, there's no way to unload the driver except via shutdown as a reboot breaks it.
Here's the exact same bug on Ubuntu in May 2011 - https://bugs.launchpad.net/ubuntu/+sour ... bug/775543
Same behavior down to how you plug in devices and multiple attempts to get drives recognized.
Duo V2 lspci -v01:01.0 USB Controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04) (prog-if 30)
Flags: bus master, fast devsel, latency 0, IRQ 9
Memory at e0000000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [50] Power Management version 3
Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [90] MSI-X: Enable- Count=8 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] #1033
Kernel driver in use: xhci_hcd
The Duo V2 has the same NEC controller as in that bug report with a different revision.
After shutting down and rebooting at least 6 times the drive was finally recognized. Still can't reboot and be able to use USB3.0. Speeds were immediately in the proper range though. Since no Jedi has responded I will initiate a trouble ticket for engineering at Netgear. - ColonelPanikAspirantAll I can say is wow. Hung up on 6 times by Netgear support since 4pm. Finally got through by being transferred from another department. Tech would not create a ticket for me. NO SUPPORT FOR THIS DEVICE apparently. He offered to contact me whenever there is an update to the firmware. I asked him if he was just not going to create a ticket or what and at that point he just stops responding. He got my callback number at the beginning of the call. No callback so I assume there was no phone problem. I hung up after 4 minutes of silence. I will try once more before returning this and the new working Netgear router I just bought a week ago. Really shocked at the quality of support so far. I hope this is just due to one bad tech and a flood of post-xmas calls.
**update - Just spoke with a few other people and created a case regarding this. Looks like the hangups and first call were just bad luck.
- Jul 18, 2020Retired_Member
