ollybowman
Nov 08, 2013Aspirant
ReadyNAS Duo V2 no Internet Connection
I've Got a ReadyNAS Duo V2 which works fine for storage and backups, but the unit itself isn't connected to the internet at all, and I can't seem to be able to get it to connect. I've just installed t...
mdgm-ntgr
Nov 08, 2013NETGEAR Employee Retired
Is your NAS configured to use DHCP or have you set a static I.P. address on it?
Are the DNS and Gateway settings correct?
