ollybowman
Nov 08, 2013Aspirant
ReadyNAS Duo V2 no Internet Connection
I've Got a ReadyNAS Duo V2 which works fine for storage and backups, but the unit itself isn't connected to the internet at all, and I can't seem to be able to get it to connect. I've just installed t...
F_L_
Nov 08, 2013Tutor
StephenB wrote: 8.8.8.8 is Google's public DNS server.
F.L. wrote: Try 192.168.1.1 as GW and 8.8.8.8 for DNS
There are some other choices - you might try pinging them, and pick the one with the shortest round trip time.
There's a list here: http://pcsupport.about.com/od/tipstrick ... ervers.htm
I know. It is just a quick way to test if it´s working.
Easy to change afterwards
