_Thumper_
Oct 22, 2014Aspirant
Readynas Duo v2 poor performance on SMB connection
Hi Everybody,
when I connect to my ReadyNAS trought a SMB connection I always obtain only 10MB/s read and write (it depends on the disk: less space seems to upgrade performance :shock: ). The funny side is that with the same machine (Ubuntu 14.04) and a CIFS connection I obtain 30 MB/s read/write which is still too slow for streaming 1080p movie but acceptable for large file moving... My RAIDiator has been upgrated to 5.3.11 and I experimented this situation with different desktop (Win7/8, Ubuntu, FreeBSD, etc.) and different HDD type. At the beginning I was using small 500GB WD on HCL but now I have upgraded to Seagate NAS 4TB with the same problem, even with slightly better performance (+1MB/s).
The client are connected through a Netgear 8 port Gigabit Switch with cat.6 cable. So network connection should not be an issue.
My new 104, with the same disk, perform much better.
Any help is appreciated.
T.
T.
- mdgm-ntgrNETGEAR Employee RetiredThere is some trade-off between better compatibility with modern OSes and performance with some models.
What version of RAIDiator are you running? - Nutty667Aspirant5.3.10.
I meant various nasware OS's. - mdgm-ntgrNETGEAR Employee RetiredFor the 104 updating to 6.2 once that is available should help performance.
As for the Duo v2 updates for legacy devices have a focus on bug fixes and security fixes.
Can you send me your logs (see link in my sig)? - Nutty667AspirantSent.
Just upgraded to the latest version which has some security fixes in. SMB share read speed seems marginally better, but I dont know if this is just as its rebooted. Getting around 38MB/s constant now. - mdgm-ntgrNETGEAR Employee RetiredI see you last did a factory reset on 5.3.2. If you still encounter performance issues it may be worth considering doing a backup, factory default (wipes all data, settings, everything) and restoring your data from backup. This would get you a clean setup on the latest firmware. Over time some changes such as some filesystem improvements require a factory reset on newer firmware to take advantage of. We do our best to achieve good results with units last factory reset on very old firmware.
I see that one of your disks is a WD Green disk with a huge Load Cycle Count - Nutty667AspirantYeah I think the last time I did a factory reset was when some firmware update broke the system when it was switched off with power timer active.
Not sure how viable a factory reset is atm, as I dont have enough storage to back everything up. I may invest in another NAS soon.
Yeah the WD green is the older of the two drives. My previous green died and I replaced it with a red. What does Load Cycle Count refer to, and is it bad that its high ? Theres no actual errors reported in the SMART data.
I will probably replace that green with another red very soon. - Nutty667AspirantAhh isn't the Load Cycle Count referring to the number of times the head gets parked or something. I vaguely remember there being some kind of firmware issue causing that to get excessive on WD Green's.
- mdgm-ntgrNETGEAR Employee RetiredYou can change the timer using idle3-tools: http://www.readynas.com/forum/viewtopic.php?f=11&t=59700
Yes, the load cycle count does refer to the number of times the head gets parked. The parking threshold on the green drives is set appropriately for windows PCs, but is too short for linux, so the heads park very frequently.Nutty667 wrote: Ahh isn't the Load Cycle Count referring to the number of times the head gets parked or something. I vaguely remember there being some kind of firmware issue causing that to get excessive on WD Green's.
There's a nominal spec of 300K load cycles, though my drives are well above that and aren't showing any issues.
You can run WDIDLE3 to adjust this threshold if you wish. Or just plan to replace the drive with another red at some point. - Nutty667AspirantI'll stick another red in there, that drives getting on a bit anyway, and it'll align the drive models in use.
I'll try moving everything off after that and doing a factory reset, see it that improves things.
