Snoopyonline78
Dec 30, 2020Aspirant
Readynas duo v2 with st3000dm001
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a new one but I read it in the community that there are problems between the old model of my drive and the new ST3000DM001. somebody knows if I can buy a new model of ST3000DM001 and my raid willwork and syncin properly? Seagate Desktop ST3000DM001 disco rigido interno 3 TB (3,5 pollici), 7200 rpm, 64 MB di cache, SATA III) https://www.amazon.it/dp/B006KCX0UE/ref=cm_sw_r_cp_api_fabc_ljl7FbV2YZWNM
Snoopyonline78 wrote:
Dear all, thanks for your help. I decided for the Seagate ironwolf pro 4TB 7200rpm CMR.
Will it work?Yes.
Dear community I have only I think a simple question since eight years I have got 2x 3 TB hard drives ST3000DM001-9YN166 in my nas. yesterday one gives error and so I want to change the disk with a new one but I read it in the community that there are problems between the old model of my drive and the new ST3000DM001. somebody knows if I can buy a new model of ST3000DM001 and my raid willwork and syncin properly?Don't get a new Barracuda.
If you want a 7200 rpm model, you can go with the Exos (ST3000NM005) https://www.newegg.com/seagate-enterprise-capacity-3-5-st3000nm0005-3tb/p/1Z4-002P-00148
If you increase the size to 4 TB or more, you would have more enterprise-class drive options. You won't see any capacity growth immediately - you'd need to replace both drives to get that.
Other 3 TB options include the Seagate Ironwolf drive (ST3000VN007) and the Western Digital TB WD30EFRX (not the WD30EFAX). They aren't 7200 rpm, but they will work fine.
- Snoopyonline78AspirantDear all, thanks for your help. I decided for the Seagate ironwolf pro 4TB 7200rpm CMR.
Will it work?
Kindly regads- StephenBGuru - Experienced User
Will it work?Yes.
Thanks a lot StephenB!
i have some questions to your answer:
You: Don't get a new Barracuda.
Me: You mean, the new models are not affidable? or is the performance bad?
You: If you want a 7200 rpm model, you can go with the Exos (ST3000NM005) https://www.newegg.com/seagate-enterprise-capacity-3-5-st3000nm0005-3tb/p/1Z4-002P-00148
Me: Thanks, but this means, i have to change the second disk too, or will this be combatile and working in Mirror-Raid mode too?
My wish is to spend as little as possible and have a mirrored raid sistem again
- SandsharkSensei
The new Barracuda drives are SMR, which will cause serious performance issues in RAID. Probably a bit less on that generation of NAS without BTRFS, but still not recommended.
The drives do not have to match except in size or the new one can be bigger, though you get no immediate usable space increase. If the rotation speed doesn't match, the NAS might complain (OS6 units do, I don't know about OS5.x), but it should work just fine.
