simon0117
Mar 31, 2017Tutor
ReadyNAS Duo v2 won't boot with disk light continuously blinking
Long story short, there was a power outage a couple of weeks ago, and I have to manually press the ReadyNAS power button when the power came back on. I got the email notification about improper shutd...
simon0117
Mar 31, 2017Tutor
I just hard-booted it again and it came up in RAIDiator. It started syncing, but then gave up telling me my 2nd drive was dead! Then I was able to go into frontview and do a graceful reboot. It started syncing and it seemed to be chugging along so I left it alone for a while. When I came back to check it, frontview said that it had gotten up to 2% syncing, but the ReadyNAS has disappeared from the network again with the 2nd drive light blinking continuously. Now what? :-(
- FramerVApr 03, 2017NETGEAR Employee Retired
Hi simon0117,
Do you remember the type of RAID was it configured to?
Would be best if you would consider calling support as well for your case.
