simon0117
Mar 31, 2017Tutor
ReadyNAS Duo v2 won't boot with disk light continuously blinking
Long story short, there was a power outage a couple of weeks ago, and I have to manually press the ReadyNAS power button when the power came back on. I got the email notification about improper shutd...
simon0117
Apr 03, 2017Tutor
Xraid. I don't think I can call support, this duo is very old.
- StephenBApr 04, 2017Guru - Experienced User
simon0117 wrote:
Xraid. I don't think I can call support, this duo is very old.You could still try paid support via my.netgear.com.
Are you sure you have a duo v2? The labels are confusing, and many v1 owners mistakenly think they have a v2. Read this guide before replying: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Do you see one of the blinking led patterns below?
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationThough from your description it sounds like one of the drives has failed. Try powering down, removing disk 2 again, and then restarting. Then download the log zip from the web ui and look at the SMART status for the disks. You might also test both disks with vendor diags in a Windos PC (lifeguard for western digital, seatools for seagate).
