simon0117
Mar 31, 2017Tutor
ReadyNAS Duo v2 won't boot with disk light continuously blinking
Long story short, there was a power outage a couple of weeks ago, and I have to manually press the ReadyNAS power button when the power came back on. I got the email notification about improper shutd...
simon0117
Apr 15, 2017Tutor
Before the factory reset it would startup loud but then quieted down after it booted up. Now it doesn't stop and I have no idea how to figure out why. I think 4411 RPM is rather high isn't it?
Maybe when I was removing and inserting the drives I blew into the case several times to blow the dust out. Is there some sort of sensor that regulates the fan speed?
- StephenBApr 16, 2017Guru - Experienced User
4411 is very high, the 1875 you posted earlier is more typical.
I think the sensors are working, since you see the temps and the fan RPM.
I don't know what the next step would be here, perhaps Sandshark has a suggestion?
- SandsharkApr 16, 2017Sensei
I'm surprised you can even access Frontview. Usually, when the fans fail to quiet at start-up, it means the system did not fully boot. It certainly sounds like some process is not running properly unless the fan controller just coincidently went out when you did the default -- and in a way where the fan is at full speeed, not zero.
If it was doing this before you restored your data, it would have been best to try and figure it out then. It may need another factory default. I'd certainly try an OS install.
