simon0117
Mar 31, 2017Tutor
ReadyNAS Duo v2 won't boot with disk light continuously blinking
Long story short, there was a power outage a couple of weeks ago, and I have to manually press the ReadyNAS power button when the power came back on. I got the email notification about improper shutd...
simon0117
Apr 15, 2017Tutor
Before the factory reset it would startup loud but then quieted down after it booted up. Now it doesn't stop and I have no idea how to figure out why. I think 4411 RPM is rather high isn't it?
Maybe when I was removing and inserting the drives I blew into the case several times to blow the dust out. Is there some sort of sensor that regulates the fan speed?
