simon0117
Mar 31, 2017Tutor
ReadyNAS Duo v2 won't boot with disk light continuously blinking
Long story short, there was a power outage a couple of weeks ago, and I have to manually press the ReadyNAS power button when the power came back on. I got the email notification about improper shutd...
jak0lantash
Apr 17, 2017Mentor
I presume you're talking about an "OS Reinstall", so you can read info about it here: https://kb.netgear.com/20898/ReadyNAS-ReadyDATA-Boot-Menu
Apr 17, 2017Guru - Experienced User
Yes, Sandshark meant to type OS reinstall.
It will reset the IP address to use DHCP and also the admin password to the factory default (netgear1 in your case). It should not destroy your data. If you follow the instructiions in jak0lantash's link, then keep in mind that you have a v1, and not a v2
The OS reinstall is a bit of a long-shot, but it might do the trick. Let us know.
- jak0lantashApr 17, 2017Mentor
StephenB wrote:keep in mind that you have a v1, and not a v2
Oh yes yes yes, forgot to mention that. And it's critically important that you follow the steps for v1, NOT for v2.
- simon0117Apr 18, 2017Tutor
Followed instractions at http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
The only thing that seemed to change was the password, which I changed back.
The fan RPM is now 4687 !
Any other ideas? I may have to get another NAS, the fan noise is driving me crazy!
- StephenBApr 18, 2017Guru - Experienced User
simon0117 wrote:
Any other ideas?
You could try another factory reset I guess.
It might be time. All the OS6 NAS are a lot faster then the duo, and have more storage capacity.
