Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
Can you put the drive in the PC and delete the partitions on it, then put it back in the NAS?
When you try the factory default are you doing this?:
1. Power down NAS if it is on.
2. Press and hold reset button
3. Turn ReadyNAS on
4. Continue to hold reset button. The disk LEDs should flash twice. Once after 5 seconds and a second time after 30 seconds. Release after the second blink.
Welcome to the forum!
3. Turn ReadyNAS on
