Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
Crookz
Thanks for the quick reply.
Will try deleting partitions, however I did the exact steps you described but the disk LEDs don't flash as the power button boot menu does.
It just seems to be booting normally, a few flashes of the arc light then into error feedback.
