Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
With the partitions deleted on the disks if you simply put the disks in and power on what happens? The NAS should detect blank disks and automatically wipe them.
