Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
Have you confirmed that both disks are fine? What about if you try with just one disk? Does that work.
See also http://www.readynas.com/kb/faq/boot/raidar_status_said_corrupted_root_during_factory_reset_or_installation._what_should_i_do
Please run the memory test: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
What you should see is shown here: http://www.readynas.com/forum/viewtopic.php?f=11&t=26993
