Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
Crookz
I'm only using one disk anyway. The disk is fine. I think I screwed up as a disk wasn't installed when I turned the device on for the first time, and that a reset would fix it? I'm just confused why I cant get it to reset (before I go more drastic).
