Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
You should see it come up in RAIDar (http://www.readynas.com/downloads) and after it boots show "Click Setup"
Sounds to me like you may have bad memory or a problem with the flash.
