Crookz
Jan 12, 2012Aspirant
ReadyNas Duo will not factory reset
Hi all, Ive just bought a new unit (rnd2000-100) and on first setup with a (compatible) used 2tb ex pc drive resulted in corrupt root in raidar and error light sequence 3 (bad contents on root of d...
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
Are you able to try a different disk to see if that makes a difference?
Don't do a boot recovery unless support (http://www.readynas.com/support) requests you to. If you have a faulty unit return it to your seller in exchange for a new one as NetGear replacements are refurbs.
