immagikman
Dec 12, 2014Aspirant
ReadyNAS Endless cost cycle
Ok I realize that once upon a time there were physical limits to volume size, Ive had the ReadyNAS, ReadyNAS+, And now have ReadyNAS Pro (6 bay) and a ReadyNAS Ultra6 and yet I am faced with STILL ...
ReadySECURE
Dec 12, 2014Apprentice
immagikman wrote: Yes I did check the list which is what prompted this post....perhaps I have a dated link? But the fact remains I still have the Pro and Ultra6 which SHOULD be able to support large drives and yet have no support :(
Also if you compare the 314 and the 514 they show different volume maxes for no apparent reason.
The Pro and Ultra6 run RAIDiator 4.2. The limitations you have on there are ext4 and md. These are also end of life products.
For instance, if you take a ReadyNAS Pro6 and put 6 6TB drives in it, and issue a factory default, you should have around 30TB, but no possible XRAID expansion, since the limitations to expand is after 16TB.
We don't have a 514. We have a 516.
