DarekDan
Aug 19, 2015Aspirant
ReadyNAS NV+ crashes under heavy load
I was copying very large database backup files to my ReadyNAS NV+ (RAIDiator 4.1.14) using RoboCopy with 4 threads, and it resulted in the device going "off-line", meaning the power was still on, but...
- Aug 25, 2015
Can't boot anymore. Claiming a bad disk now. Switching to QNAP. Better quality.
vandermerwe
Aug 19, 2015Master
Well it depends on what the cause is.
How full is the data volume?
Have you verified that all the disks are ok, perhaps by testing using vendor tools?
Do you have ssh enabled?
If so could you ssh in and:
df -h df -i
....although this does not sound like a full OS partition.
DarekDan
The volume is almost empty otherwise. The disks have been verified as OK. I don't have SSH enabled.
- StephenBAug 19, 2015Guru - Experienced User
The OS partition isn't visible, and it possibly could be filling.
First of all, I suggest making a backup of your data - it clearly is at risk if the NAS is crashing/unstable.
- DarekDanAug 25, 2015Aspirant
- mdgm-ntgrAug 25, 2015NETGEAR Employee Retired
Disks can and do fail. We have no control over the quality of hard disks that are produced.
If you boot the NAS with the bad disk removed you may well find that that resolves the problem.
