DarekDan
Aug 19, 2015Aspirant
ReadyNAS NV+ crashes under heavy load
I was copying very large database backup files to my ReadyNAS NV+ (RAIDiator 4.1.14) using RoboCopy with 4 threads, and it resulted in the device going "off-line", meaning the power was still on, but...
- Aug 25, 2015
Can't boot anymore. Claiming a bad disk now. Switching to QNAP. Better quality.
DarekDan
The volume is almost empty otherwise. The disks have been verified as OK. I don't have SSH enabled.
Aug 19, 2015Guru - Experienced User
The OS partition isn't visible, and it possibly could be filling.
First of all, I suggest making a backup of your data - it clearly is at risk if the NAS is crashing/unstable.
- DarekDanAug 25, 2015Aspirant
- mdgm-ntgrAug 25, 2015NETGEAR Employee Retired
Disks can and do fail. We have no control over the quality of hard disks that are produced.
If you boot the NAS with the bad disk removed you may well find that that resolves the problem.
But you do have control over your firmware, your hardware, and your customer support. Stating in one part of the site that installation of SSH violates terms of use and voids support, than in other, like this forum, advising to run low-level file system commands over SSH, is contradictory. So, good ridance, I will continue using your network switches, but your NAS devices are off-limits to me and my friends, until quality improves.
