DarekDan
Aug 19, 2015Aspirant
ReadyNAS NV+ crashes under heavy load
I was copying very large database backup files to my ReadyNAS NV+ (RAIDiator 4.1.14) using RoboCopy with 4 threads, and it resulted in the device going "off-line", meaning the power was still on, but...
- Aug 25, 2015
Can't boot anymore. Claiming a bad disk now. Switching to QNAP. Better quality.
Aug 19, 2015Guru - Experienced User
The OS partition isn't visible, and it possibly could be filling.
First of all, I suggest making a backup of your data - it clearly is at risk if the NAS is crashing/unstable.
DarekDan
Aug 25, 2015Aspirant
- mdgm-ntgrAug 25, 2015NETGEAR Employee Retired
Disks can and do fail. We have no control over the quality of hard disks that are produced.
If you boot the NAS with the bad disk removed you may well find that that resolves the problem.
- DarekDanAug 25, 2015Aspirant
But you do have control over your firmware, your hardware, and your customer support. Stating in one part of the site that installation of SSH violates terms of use and voids support, than in other, like this forum, advising to run low-level file system commands over SSH, is contradictory. So, good ridance, I will continue using your network switches, but your NAS devices are off-limits to me and my friends, until quality improves.
- StephenBAug 25, 2015Guru - Experienced User
To be clear - No one working for Netgear suggested you run SSH. Neither vandermerwe nor I work for Netgear.
Though they have never said here that use of SSH automatically voids the support warranty (and in fact they have explicitly said that it does not void the warranty). They reserve the right to withdraw support, but in my experience that only happens in cases where the use of SSH created the problems. Do you still have warranty left on your ancient NV+ ???
