NSS-John
Sep 21, 2017Initiate
ReadyNas NV+ Default Username/Password
Hi, I found an older ReadyNas NV+ unit at my new job, Part number is RNV2-S2-0000. I found instructions online how to reset it to factory default, which I have (seemingly) successfully done. I ca...
- Sep 21, 2017
NSS-John wrote:
Anyone know what the correct username/password for this model is when reset to factory? I would love to get some use out of this thing!
The normal default is admin/netgear1. If the unit is very old (as I suspect yours is), it could be admin/infrant1
The current firmware would be 4.1.16; you might need to install that manually (update server URLs have sometimes changed over the years).
Sep 21, 2017Guru - Experienced User
NSS-John
Ahh, God bless you StephenB! It was admin/infrant1! Now I can use this unit and I will upgrade the firmware (whihc currently is RAIDiator™ v3.01c1-p6 [1.00a034]! :smileyvery-happy:
Thanks so much for your quick reply!
