robmorris77
Jan 14, 2016Aspirant
Readynas nv+ ... reset battery ?
Hi, Hopefully someone will be able to help me with the following query ? I have a ReadyNAS NV+ with the same problem as detailed in this thread : https://community.netgear.com/t5/Using-yo...
JennC
Jan 14, 2016NETGEAR Employee Retired
Hello robmorris77,
Welcome to the community!
https://community.netgear.com/t5/Using-your-ReadyNAS/WTB-ReadyNAS-NV-power-supply/td-p/921317#p337936 should now be visible to you.
Please also see HOW TO RESET CMOS TIMER IN ReadyNAS NV, it is similar to NV+. That must be the one you need.
Jan 14, 2016Guru - Experienced User
JennC wrote:
Please also see HOW TO RESET CMOS TIMER IN ReadyNAS NV it is similar to NV+. That must be the one you need.Regards,
If you can get to it, you might as well replace the battery while you are doing this (should be a CR2032 or equivalent). But from the picture that looks a bit challenging.
- JennCJan 14, 2016NETGEAR Employee Retired
Hello robmorris77,
No problem. Let us know.
- robmorris77Jan 15, 2016Aspirant
Thanks everyone, I've got a pair of RN314's on order and 10x WD Red 4TB's due by the end of next week, so hopefully will be back up and running by a week Sunday !
I've posted this thread also https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-NV-Data-Migration/m-p/1034589#M101945
So if you lovely helpful people would be able to assist/advise further it would be most appreciated !
Rob
