Greigw
Feb 18, 2019Aspirant
ReadyNas nv+ V1 UPS not detected
I have an old ReadyNAS nv+ v1. When I connect it to my UPS - ?? using one of the USB ports on the back Frontview does not show that the ups is detected. But when I unplug the usb cable I get a mess...
Greigw
Feb 19, 2019Aspirant
Thanks for responding. See my reply to another response.
Feb 19, 2019Guru - Experienced User
Is the cable connecting the NAS to the UPS a normal USB cable?
Or is the UPS output a serial connector that is adapted to USB on the NAS end?
- GreigwFeb 19, 2019Aspirant
Hi StephenB,
It is a normal USB cable with the square connector (as found on usb connected printers) on the end that plugs into the UPS and the standard flat connector on the other end.
- StephenBFeb 20, 2019Guru - Experienced User
Greigw wrote:It is a normal USB cable with the square connector (as found on usb connected printers) on the end that plugs into the UPS and the standard flat connector on the other end.
Thx. Generally speaking UPS that use serial connectors+adapters to USB aren't monitored correctly. However, that's not your particular problem, since you have a standard USB cable. It might be worth trying all the USB ports on the NV+, and confirming that they behave similarly.
Your UPS isn't listed on https://networkupstools.org/ddl/Proline/ so it might not be compatible.
Even if the UPS can't be monitored, there is still value in using it - since in many cases the power is restored before the battery runs down.
