jalia
Aug 16, 2017Aspirant
ReadyNAS NV+ v2 - No volume shows up after disk swap
Hi.
I've had my ReadyNas for 5 years and I originally set it up with 4 disks in Raid 0. All disk have shown up as volumes in the System->Overview section. A few weeks back I decided to get rid ...
JennC
Aug 18, 2017NETGEAR Employee Retired
Hello jalia,
That must be 4 disks, not 5 because that is a 4-bay NAS.
Which RAID level did you configure on the NAS? I noticed that the disks do not have the same capacity.
If you do not have backup yet, please back up the data first.
Welcome to the community!
- jaliaAug 20, 2017Aspirant
Yes, the 5 disk was a typo. It is of course 4 disks.
As I've written I did choose Raid 0 which is ever disk for them selves so I don't understand why the new disks aren't showing up. I have even added the same disks that I used before after they were formatted. Not even they are showing up
- mdgm-ntgrAug 28, 2017NETGEAR Employee Retired
I believe this can happen sometimes on the v2. One option would be to update your regular backup, do a factory reset (wipes all data, settings, everything) and restore your data from backup.
