danyee
Nov 16, 2012Aspirant
ReadyNAS NV won't power on
I have a ReadyNAS NV that I bought back in April 2006 that will no longer power on. 1) I'm suspecting that the power supply has gone bad. Is there a way to check if this is the case? If I need a ...
mdgm-ntgr
Nov 17, 2012NETGEAR Employee Retired
Yes that is the correct PSU for your system.
Did you notice a burning smell? You could remove the PSU and check for burnt capacitors or other damage: http://www.readynas.com/kb/faq/hardware/how_do_i_replace_the_stock_power_supply_on_the_readynas_nv
