crond
Nov 02, 2018Aspirant
ReadyNAS OS6 issues with Ultra 4
Hi All,
I'm having trouble with OS6 on latest OS6 firmware and wondering if somebody saw similar issues.
I have Ultra4 with 4x4TB WD Reds. I had no issues on OS4.
Upgrade to latest version went...
Nov 02, 2018Guru - Experienced User
crond wrote:
how to downgrade back to OS4 ? I found couple link on this forum but all of them are dead
This post has a working link: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/m-p/859412#M2683
crond wrote:
So from my side I have 2 questions, does anyone run legacy model pro4/6 ultra4/6 with WD REDs on OS6 ?
I'm sure that a lot of people do.
On the memory - did you try running the diagnostic from the boot menu?
- crondNov 02, 2018Aspirant<p>Thanks for the link. </p>
<p>I didn't run memtest, was planning to upgrade memory anyway. </p>
<p>Do you now where did http://netgear.nas-central.org/wiki/Convert_RAIDiator_to_ReadyNASOS go ?</p>
<p> </p>
<p> </p>- StephenBNov 03, 2018Guru - Experienced User
crond wrote:
I didn't run memtest, was planning to upgrade memory anyway.Ok. Of course bad memory would affect OS 4 also, but perhaps not in the same way.
crond wrote:
Do you now where did http://netgear.nas-central.org/wiki/Convert_RAIDiator_to_ReadyNASOS go ?I don't know who hosted nas-central.org, but the entire site disappeared in mid-August 2018.
The files themselves were maintained by mdgm and were hosted on a Netgear server, but that folder was deleted when he left at the end of August. Hopefully the new links will keep working.
- RottenweilerNov 09, 2018Guide
I have three Pro6 (actually 2 RNP Pro6 and 1 RNP Business 6) and an Ultra 4 ALL running OS6 with WD Red drives, perfectly. Drives are varing sizes from 3 to 6TB in each of the different units, but identical within each unit) No issues. On OS 6.9.4.HF1. Mine have all been working well, in fact much better than expected given the age of the boxes and the fact that they were originally "unsupported" on OS6. So it IS certainly possible, very good luck with that combination here, at least in my case. Best wishes, I hope you are able to get it sorted.
