Partha-Dash's avatar
Partha-Dash
ReadyNAS Portal is under maintenance
Hi All,   I would like to bring it to all of your’ s notice that the portal of Netgear(https://www.netgear.com/mynetgear/registration/login.aspx) where you can see  or can register your products ...
  • kohdee's avatar
    kohdee
    Oct 12, 2018
    Alright, I made a change to the ops@ work e-mail account; can you check now to see if you see your assets?
ProSupport for Business
