Readynaspro
Sep 23, 2011Aspirant
Readynas Pro - fails to send email alerts - HELP!
Have a ReadyNAS Pro with latest RAIDiator 4.2.19. I have not been able to SUCCESSFULLY send email alerts, for a year now. With this latest firmware, and previous versions. I used to be able to rece...
Buckets
Nov 26, 2011Initiate
I too could not get email and didn't find the answer in this thread. My solution was simple once I realized that I had not defined the gateway and dns servers on the Network tab. Once I entered those ip addresses, I tried 3 different email accounts - att yahoo, bellsouth, and gmail - all worked successfully. I DID NOT have to use the SMTP settings. If you don't know your gateway/dns IP addresses - open cmd window (start, accessories, command prompt) which is a DOS window - type ipconfig /all to get detailed information about your network.
