suthers
Jul 05, 2015Aspirant
ReadyNAS Pro 2 - how to find results from disk check
Hi All, Just performed a factory reset on my ReadyNAS Pro 2 with all new disks installed. BIOS version ReadyNAS-ProUltra2 V1.8. After this, booted into Disk Test mode and RAIDar showed the device ...
mdgm-ntgr
Jul 05, 2015NETGEAR Employee Retired
In e.g. disk_smart.log you should see the result of the extended offline test for each disk.
