steveoelliott
Jun 23, 2015Luminary
ReadyNAS Pro 6 Became Inaccessible - Support Case: 25326829
Hi all, This morning a NAS I support in business became inaccessible. Status screen showed IP address etc and lights on but would not even respond to ping. Had to press and hold power button to pow...
steveoelliott
Jun 24, 2015Luminary
Well, what I do find interesting is the fact the USB drive is even doing anything. If you look at the full logs uploaded to my case you will see that I had already disconnected it from Frontview but had not gone to site to remove it as yet.
I suspect the drive may have been the trigger but I don't see how it came to get reconnected and furthermore lead to a crash with no other dumps etc.
If there were other random lockups then yes I would look at disk and memory tests. Interestingly whilst the device was inaccessible and didn't respond to pings etc, pressing the button on the front did display IP address, I do suspect this is handled separately to the underlying OS though.
You can see why I am reluctant to pay for extended support in this instance because I suspect they won't be able to find the fault. It was more curiosity to see if anybody else had seen the same behaviour from your large customer base.
