daminite
Dec 08, 2015Aspirant
Readynas Pro 6 rebooting during resync - after factory reset
Need help since I factory rest my Readynas it seems to reboot during the resyncing process Here is what I see in logs from admin page: Tue Dec 8 2015 10:51:56 Volume: Resyncing started...
mdgm-ntgr
Dec 09, 2015NETGEAR Employee Retired
Have you checked the health of your disks?
daminite
Dec 09, 2015Aspirant
I am running brand new WD 3TB drives
- StephenBDec 09, 2015Guru - Experienced User
Check the SMART stats anyway.
- daminiteDec 09, 2015Aspirant
Here is the data I think you are requesting. Only thing I see abnormal is the command error on disk 6
realloc_sect realloc_evnt spin_retry_cnt ioedc cmd_timeouts pending_sect uncorrectable_err ata_errors timestamp time -------------------- ------------ ------------ -------------- ---------- ------------ ------------ ----------------- ---------- ---------- ---------- --------- Disk1 0 0 0 0 0 0 0 0 1449531196 12/7/2015 23:33:16 Disk2 0 0 0 0 0 0 0 0 1449531196 12/7/2015 23:33:16 Disk3 0 0 0 0 0 0 0 0 1449531196 12/7/2015 23:33:16 Disk4 0 0 0 0 0 0 0 0 1449531197 12/7/2015 23:33:17 Disk5 0 0 0 0 0 0 0 0 1449531197 12/7/2015 23:33:17 Disk6 0 0 0 0 1 0 0 0 1449531197 12/7/2015 23:33:17 - StephenBDec 09, 2015Guru - Experienced User
Yes, that was it.
Since the pro is rebooting more than once, the single command timeout can't be the trigger.
